Home Community
Advice Needed for Switching ~1000W Voltage Sources to Inverter
Welcome, Guest. Please login or register.
May 23, 2013, 08:12:45 AM
Home Help Search Calendar Login Register
News: trade your components on this new board: "Components trade"
Advertisements
No New Posts
Today at 01:39:33 AM
in
Advertisements
by google
+  Electronics-Lab.com Community
|-+  Electronics Forums
| |-+  Power Electronics (Moderators: Gazza, Hero999)
| | |-+  Advice Needed for Switching ~1000W Voltage Sources to Inverter
« previous next »
Pages: [1] Print
Author Topic: Advice Needed for Switching ~1000W Voltage Sources to Inverter  (Read 967 times)
dwarnecke11
Newbie
View Profile
« on: April 15, 2011, 10:45:26 AM »
As part of my senior design project, I need to be able to switch between two 12V, ~90A sources as an input to a large 1100W inveter.  I'm planning on using a 93000uF 40VDC capacitor to support the load during the brief switchover time.
What method of switching should I use?  Mechanical relay, solid state relay, MOSFET, etc?  I need to switch a large amount of current at 12VDC as quickly as possible.  What about using a make-before-break configuration?
The two sources will be a large battery bank charged by wind and solar, and a gas turbine generator.
Logged
Hero999
Global Moderator
Electronics God
View Profile
« Reply #1 on: April 15, 2011, 11:37:26 AM »
Assuming the minimum operating voltage is 10V and the current is 100A, the 93,000
Logged
I also post at:
http://www.silicontronics.com
I do not answer private messages asking for help because no one else can: benefit from advice I may give or correct me if I'm wrong.
Please ask on the open forum if you have a question: if I know the answer, I'll be happy to help.
einstein0
Newbie
Gender: Male
View Profile Email
« Reply #2 on: June 25, 2011, 11:59:26 AM »
Use a heavy rectifier (Dual 100 A). If necessary you could bypass them by using a bistable relay of an appropriate contacts rating.
I used this system in my campervan: 5 kWh/12V Batterybank & 140 Amp Alternator, supplying a 1000 W/12V inverter...
einstein0
Logged
Pages: [1] Print
« previous next »
Jump to:
Advertisements
No New Posts
in
Advertisements
by google
Login with username, password and session length
Powered by MySQL Powered by PHP Powered by SMF 1.1.18 | SMF © 2013, Simple Machines Valid XHTML 1.0! Valid CSS!
Search Site | Advertising | Add your link here | Contact Us | Android TV Box
Elektrotekno.com | Free Schematics Search Engine | Electronic Kits | Electronic Accessories
