Home Community
Powering a Canon A470?
Welcome, Guest. Please login or register.
June 19, 2013, 09:25:43 PM
Home Help Search Calendar Login Register
News: trade your components on this new board: "Components trade"
Advertisements
No New Posts
Today at 01:39:33 AM
in
Advertisements
by google
+  Electronics-Lab.com Community
|-+  Electronics Forums
| |-+  Power Electronics (Moderators: Gazza, Hero999)
| | |-+  Powering a Canon A470?
« previous next »
Pages: [1] Print
Author Topic: Powering a Canon A470?  (Read 803 times)
scruff1
Newbie
View Profile
« on: April 16, 2011, 04:31:26 AM »
Hello all,it's been since 2008 when I was last on here but my username "scruff" would not activate. So now I'm scruff1 Grin
Anyway,I'm hoping to use an alternative means to improve power duration on a Canon A470 digital camera. The conventional AA batteries don't last long,especially for 2 hours of video recording.  The DC socket on the camera is 3.15v which I've know purchased a jack.  I was contemplating on wiring that to a Tamiya type connector (female)
And then connect a radio controlled 5000mAh battery pack.  If this setup is ok,would a 7.2v battery be ok,or is it too much juice?
I'm hoping to do the same with a digital video recorder,which uses a 5v power point.  Both are mobile applications where a static power socket can't be used.
thanks
Paul
Logged
Hero999
Global Moderator
Electronics God
View Profile
« Reply #1 on: April 16, 2011, 05:48:26 AM »
You need a DC-DC converter to get 3V from the higher input voltage.
Have you measured the current drain of the camera? If it drains two AAs in 2 hours 1A is probably a good estimate but the peak current demand could be higher.
Perhaps you should use a couple of D cells instead? It should last three to four times as long. If you use rechargeable D cells make sure they have a capacity of over 8500mAh, some cheap rechargeable D cells are really C or AA cells with extra padding.
Logged
I also post at:
http://www.silicontronics.com
I do not answer private messages asking for help because no one else can: benefit from advice I may give or correct me if I'm wrong.
Please ask on the open forum if you have a question: if I know the answer, I'll be happy to help.
scruff1
Newbie
View Profile
« Reply #2 on: April 17, 2011, 01:05:09 AM »
Superb reply Hero,thanks.  I'd say the D cells would be practical.  I wasn't aware that D cell packs existed.  I've only seen 3.6v sticks,would that still be too much?
Logged
Hero999
Global Moderator
Electronics God
View Profile
« Reply #3 on: April 17, 2011, 02:46:53 AM »
THey don't, you have to build your own by connecting two in series. Fortunately you can buy dual D cell holders.
Quote
I don't know, 3.6V might be too much, and if you're talking about a Li-ion cell which is 4.2V when fully charges, then it almost certainly is. The only way to know for sure is to seek advice from the manufacturer.
Logged
I also post at:
Pages: [1] Print
« previous next »
Jump to:
Advertisements
No New Posts
in
Advertisements
by google
Login with username, password and session length
Powered by MySQL Powered by PHP Powered by SMF 1.1.18 | SMF © 2013, Simple Machines Valid XHTML 1.0! Valid CSS!
Search Site | Advertising | Add your link here | Contact Us | Android TV Box
Elektrotekno.com | Free Schematics Search Engine | Electronic Kits | Electronic Accessories
