Home Community
Need Cross Reference For FQU1N60C Mosfet
Welcome, Guest. Please login or register.
May 19, 2013, 12:46:09 AM
Home Help Search Calendar Login Register
News: trade your components on this new board: "Components trade"
Advertisements
No New Posts
Today at 01:39:33 AM
in
Advertisements
by google
+  Electronics-Lab.com Community
|-+  Electronics Forums
| |-+  Datasheet/Parts requests (Moderators: hotwaterwizard, Herman the German)
| | |-+  Need Cross Reference For FQU1N60C Mosfet
« previous next »
Pages: [1] Print
Author Topic: Need Cross Reference For FQU1N60C Mosfet  (Read 1889 times)
Digonto
Guest
« on: June 02, 2011, 04:12:50 AM »
Hello Hero and Audioguru,
I have a GADMEI External TV Card which has a adapter of 5V 800mA Output and 230V 40mA Input . But this adapter has burnt out . I found that FQU1N60C (Fairchild semiconductor) Mosfet has been damaged . After searching my market I found P2N60FI (ST Semiconductor) Mosfet - but not 1N60CSad
Can I use this P2N60FI instead of FQU1N60C for my adapter ?  Huh Will it be OK ?  Huh
Logged
Hero999
Global Moderator
Electronics God
View Profile
« Reply #1 on: June 02, 2011, 01:17:02 PM »
I've no idea because I can't find a datasheet for the P2N60FI.
Finding a datasheet for the FQU1N60C was easy. I suspect you can replace it with a MOSFET with similar or better characteristics but it still might not work because other components might have been damaged. Are you sure it's just the MOSFET which is broken?
http://www.fairchildsemi.com/ds/FQ/FQU1N60C.pdf
Why not simply replace the adaptor? It's not like they're expensive?
Logged
I also post at:
http://www.silicontronics.com
I do not answer private messages asking for help because no one else can: benefit from advice I may give or correct me if I'm wrong.
Please ask on the open forum if you have a question: if I know the answer, I'll be happy to help.
Digonto
Guest
« Reply #2 on: June 02, 2011, 01:50:34 PM »
Firstly thanks for your reply .
And Sorry Hero ... that is my mistake  Sad The Correct Parts Number is STP2N60FI And yes you are right - Input Fusing Resistor (1.5 ohms) and Choke have blown out for damaging the MOSFET . I have checked the other parts - Resistor, Electrolytic & Mylar, Silicon & Crystal Diode , C1815 transistor and Chopper are OK .
A new adapter Cost is 400 Rupees and MOSFET cost is 35 Rupees . So, I am thinking to repair the adapter .
I am attaching the PDF File of STP2N60FI below . Please have a look and plz tell me will it be OK ?  Huh
Thanks Hero for your reply .
Logged
Hero999
Global Moderator
Electronics God
View Profile
« Reply #3 on: June 02, 2011, 02:53:07 PM »
Now I've found the datasheet for you, it should be easy to figure it out. What do you think?
I noticed see one obvious problem before I even looked at any of the electrical characteristics.
Logged
I also post at:
Digonto
Guest
« Reply #4 on: June 02, 2011, 03:44:49 PM »
Thanks Hero . I am waiting for your opinion ..........
Logged
Hero999
Global Moderator
Electronics God
View Profile
« Reply #5 on: June 04, 2011, 03:31:10 AM »
I won't give my opinion until you give me yours.
Have you read both of the datasheets yet?
Logged
I also post at:
Digonto
Guest
« Reply #6 on: June 04, 2011, 02:10:28 PM »
Ooooopsss........ !! May be yes .... may be no .... !! Huh I don't know .  Huh MOSFET Substitution is really hard ..... man ... !! My head is spinning  Embarrassed I am mentioning some parameters below :
Parameters----------------------------- FQU1N60C ------------STP2N60FI ------------- STP4N150
Drain-Source Voltage ------------------------ 600 V ---------------- 600 V ------------------- 1500 V
Drain-Gate Voltage -------------------------- 600 V ---------------- 600 V ------------------- 1500 V
Gate-source Voltage -------------------------
Logged
Hero999
Global Moderator
Electronics God
View Profile
« Reply #7 on: June 04, 2011, 02:51:27 PM »
As I said previously there's a problem with your substitution before you even look at the electrical specification. The package styles of the transistors you've linked to are different to the FQU1N60C which is designed to use a copper plane on the PCB as a heat sink.
Logged
I also post at:
Digonto
Guest
« Reply #8 on: June 04, 2011, 03:27:48 PM »
But Hero, may be you are talking about FQD type, not FQU . FQD is designed to lie down on the copper plane of the PCB but FQU is not designed to lie down on the PCB .
Please watch this PDF for FQD type and FQU type .
Logged
Hero999
Global Moderator
Electronics God
View Profile
« Reply #9 on: June 04, 2011, 04:59:22 PM »
The STP2N60FI looks like the closest match. The lower VGS should not be a problem, although it's not possible to be 100% sure without the schematic.
Logged
I also post at:
Digonto
Guest
« Reply #10 on: June 04, 2011, 06:23:33 PM »
Thanks Hero . Thanks a lot . I will go with your decision . STP2N60FI is available in my market and I will buy it tomorrow .
Logged
Pages: [1] Print
« previous next »
Jump to:
Advertisements
No New Posts
in
Advertisements
by google
Login with username, password and session length
Powered by MySQL Powered by PHP Powered by SMF 1.1.18 | SMF © 2013, Simple Machines Valid XHTML 1.0! Valid CSS!
Search Site | Advertising | Add your link here | Contact Us | Android TV Box
Elektrotekno.com | Free Schematics Search Engine | Electronic Kits | Electronic Accessories
