Home Community
Power supply is acting like a short but has high resistance
Welcome, Guest. Please login or register.
June 19, 2013, 04:16:10 AM
Home Help Search Calendar Login Register
News: trade your components on this new board: "Components trade"
Advertisements
No New Posts
Today at 01:39:33 AM
in
Advertisements
by google
+  Electronics-Lab.com Community
|-+  Electronics Forums
| |-+  Power Electronics (Moderators: Gazza, Hero999)
| | |-+  Power supply is acting like a short but has high resistance
« previous next »
Pages: [1] Print
Author Topic: Power supply is acting like a short but has high resistance  (Read 774 times)
abador
Newbie
Gender: Male
View Profile
« on: June 16, 2011, 10:59:30 PM »
I'm trying to get a power supply working that I recently have built but have been having constant trouble with it. The most recent problem is that the 3300 uF capacitor discharges instantly as soon as I unplug it from the wall, despite the fact that there is a 1K Ohm resistor and LED in parallel with it and the output reading is currently very low. I have seen the LED slowly get dimmer in the past. I took a resistance reading across the output when the circuit was not energized and it was about 8K and kept rising, I thought it was because the capacitor was charging but after several attempts to discharge it the resistance was still high (17K last I saw.) I have a 5K potentiometer and a 10K resistor in series with the output. I took a reading across the DC rail as well which had high resistance. This thing has me completely stumped.
Also I have been trying to make it a variable power supply and someone said I need to use the potentiometer to control the voltage via a voltage regulator, is there any way to do this with a transistor?
Logged
It is a borderline obsession at times.
Hero999
Global Moderator
Electronics God
View Profile
« Reply #1 on: June 18, 2011, 02:57:55 AM »
You forgot to post a schematic so there's no way any one can help.
Logged
I also post at:
http://www.silicontronics.com
I do not answer private messages asking for help because no one else can: benefit from advice I may give or correct me if I'm wrong.
Please ask on the open forum if you have a question: if I know the answer, I'll be happy to help.
Pages: [1] Print
« previous next »
Jump to:
Advertisements
No New Posts
in
Advertisements
by google
Login with username, password and session length
Powered by MySQL Powered by PHP Powered by SMF 1.1.18 | SMF © 2013, Simple Machines Valid XHTML 1.0! Valid CSS!
Search Site | Advertising | Add your link here | Contact Us | Android TV Box
Elektrotekno.com | Free Schematics Search Engine | Electronic Kits | Electronic Accessories
