Home Community
LM358 - Dual Low Power Operational Amplifier
Welcome, Guest. Please login or register.
May 18, 2013, 06:54:13 AM
Home Help Search Calendar Login Register
News: trade your components on this new board: "Components trade"
Advertisements
No New Posts
Today at 01:39:33 AM
in
Advertisements
by google
+  Electronics-Lab.com Community
|-+  Electronics Forums
| |-+  Theory articles (Moderator: redwire)
| | |-+  LM358 - Dual Low Power Operational Amplifier
« previous next »
Pages: [1] Print
Author Topic: LM358 - Dual Low Power Operational Amplifier  (Read 1522 times)
Davaliao
Newbie
View Profile Email
« on: August 18, 2011, 10:32:52 PM »
Utilizing the circuit designs perfected for recently introduced Quad
Operational Amplifiers, these dual operational amplifiers feature 1) low
power drain, 2) a common mode input voltage range extending to
ground/VEE, 3) single supply or split supply operation and 4) pinouts
compatible with the popular MC1558 dual operational amplifier. The LM158
series is equivalent to one
Logged
audioguru
Electronics God
Gender: Male
I'm a theory expert! $crooge and I are thrifty.
View Profile
« Reply #1 on: August 19, 2011, 07:33:49 AM »
This Chinese SPAM was also posted on another site.
The LM158 IS NOT new, it is about 39 years old.
It is noisy (hiss), has crossover diistortion and has trouble above only 2kHz.
Its max supply voltage is only 32V.
I replace it with an MC33172 that has the same very low supply current and inputs and outputs that work at its negative supply that can be ground, has no crossover distortion, has a 44V maximum supply and goes up to 35kHz.
The MC33171 is a single opamp and the MC33174 is a quad (replaces an LM124).
The LM358 is not Chinese, it is American. The MC3317x is also American.
Logged
pdp
Newbie
View Profile
« Reply #2 on: October 03, 2011, 06:44:02 PM »
What trouble?
Logged
audioguru
Electronics God
Gender: Male
View Profile
« Reply #3 on: October 03, 2011, 07:41:26 PM »
What trouble?
Its slew rate is 1/10th as high as half-decent opamps because it is low power. The low power produces horrible crossover distortion.
Its datasheet has a graph "Large Signal Frequency Response" that shows it produces an output of only 12.5V p-p at only 5kHz. At full output level of 30V p-p it barely produces only 2kHz.
Half-decent opamps are perfect at full output level at 100kHz.
Logged
Hero999
Global Moderator
Electronics God
View Profile
« Reply #4 on: October 04, 2011, 11:32:21 AM »
It's not necessarily a problem. The LM358 has many applications where its low speed is not an issue.
Logged
I also post at:
http://www.silicontronics.com
I do not answer private messages asking for help because no one else can: benefit from advice I may give or correct me if I'm wrong.
Please ask on the open forum if you have a question: if I know the answer, I'll be happy to help.
pdp
Newbie
View Profile
« Reply #5 on: October 04, 2011, 11:43:49 PM »
That MC33172 is unlikely to be a full substitute for the widespread and extremely cheap LM358. The latter can suffice in many cases. For instance, LM358 is being used even by Intel in some computer motherboards. Perhaps it's still early to write this device off.
Logged
Pages: [1] Print
« previous next »
Jump to:
Advertisements
No New Posts
in
Advertisements
by google
Login with username, password and session length
Powered by MySQL Powered by PHP Powered by SMF 1.1.18 | SMF © 2013, Simple Machines Valid XHTML 1.0! Valid CSS!
Search Site | Advertising | Add your link here | Contact Us | Android TV Box
Elektrotekno.com | Free Schematics Search Engine | Electronic Kits | Electronic Accessories
