Home Community
How to switch 3A with a mircoswitch?
May 18, 2013, 05:55:45 AM
Advertisements
No New Posts
Today at 01:39:33 AM
in
Advertisements
by google
|-+  Electronics Forums
| | |-+  How to switch 3A with a mircoswitch?
« previous next »
Pages: [1] Print
Author Topic: How to switch 3A with a mircoswitch?  (Read 629 times)
piesoup
Newbie
View Profile Email
« on: November 04, 2011, 07:45:32 AM »
Hello all
I make LED bicycle lights that draw 3A from the battery. To turn them on and off or to control the different modes, I have been using a 3A latching switch. Now to get one this small, bezel dia is 17mm and for it to be IP67 rated, they cost
Logged
audioguru
Electronics God
Gender: Male
View Profile
« Reply #1 on: November 04, 2011, 08:43:59 AM »
A "logic level" Mosfet switches very well when its gate is 4.5V or more.
Very few Mosfets switch well when their gate is only 3.7V.
Logged
piesoup
Newbie
View Profile Email
« Reply #2 on: November 04, 2011, 02:21:22 PM »
Thanks for the reply Audioguru.
So other than a relay, I should just stick with the big switch? Or is there another way for switching 3A?
Thanks again
Logged
Hero999
Global Moderator
Electronics God
View Profile
« Reply #3 on: November 05, 2011, 11:48:33 AM »
There are plenty of MOSFETs which will switch 3A with a gate voltage of 3.7V. The old IRL540 is has an RON of 0.11Ohms at VGS = 4V and ID = 14A. With a source voltage of 3.7V it'll be a bit worse but you only want to switch 3A so it should be fine.
What's the lowest battery voltage? It sounds like you're using L-ion? The trouble is it may not be good enough when the battery voltage is low. Going from the datasheet it appears it should be fine down to 3.5V.
http://www.vishay.com/docs/91300/91300.pdf
Logged
I also post at:
http://www.silicontronics.com
piesoup
Newbie
View Profile Email
« Reply #4 on: November 06, 2011, 04:49:58 AM »
Thanks Hero
I noticed that the VGS = 4V. Is that going to be a problem as a fully charged Li-Ion is 4.2v??
Also, how would I connect it to my circuit.
Drain and Source conected in series with my battery and light.
Gate, switched with a latching low current switch, but to Drain or Source? With what size resistor?
Ive found them on Farnell for less than a Pound so these would be great if I can get them to work!
Thank you for answering my questions again
Logged
audioguru
Electronics God
Gender: Male
View Profile
« Reply #5 on: November 06, 2011, 08:24:04 AM »
Your "4.2V" battery will be only 3.0V when it needs to be re-charged. The datasheet does not list the voltage lost when the gate-source is only 3V but a graph shows that a "typical" IRL540 Mosfet will have a loss of only 0.2V at 3A. A "minimum" one might have a loss of 1V or more.
Where can you buy a "typical" one?
Logged
Hero999
Global Moderator
Electronics God
View Profile
« Reply #6 on: November 06, 2011, 05:16:20 PM »
The old IRL540 will probably do but the VDS may be too high for what you're doing.
Any of the following transistors will be able to switch 3A with 3V.
http://www.onsemi.com/pub_link/Collateral/2SK4043LS-D.PDF
http://www.irf.com/product-info/datasheets/data/irl1104pbf.pdf
http://www.irf.com/product-info/datasheets/data/irl3103pbf.pdf
http://www.irf.com/product-info/datasheets/data/irl2203npbf.pdf
Logged
I also post at:
Pages: [1] Print
« previous next »
Jump to:
Advertisements
No New Posts
in
Advertisements
by google
