HI SIR CAN U TEACH ME WHATS THE PROGRAMMING OF MY PROJECT
APPENDIX A
//Author: Devakumar
//Project: Solar powered surveillance system
// This source code is used in my project]
#include <16f877a.h>
#include <math.h>
#include <stdlib.h>
#fuses HS,NOWDT,NOPROCTECT,NOLVP
#use delay (clock=20000000)
#use rs232(baud=19200,xmit=PIN_C6,rcv=PIN_C7,PARITY=N.BITS=8)
#org 0x100,0x1FFF void loader 16f877 (void) {} //16f677A
//input definition
#define STO_in_A PIN_A1 //pin3
#define STO_in_B PIN_A2 //pin4
#define CONT_A PIN_A3 //manually control //pin5
#define CONT_B PIN_A4 // Automatic // pin6
#define cont_C PIN_A5 // pin7
#define SENSOR PIN_C1 //pin16
//output definition
#define PIC_A 0 //PIN_B7
#define PIC_B 1 //PIN_B6
#define CAM_A 2 //PIN_B5
#define CAM_B 3 //PIN_B4
#define BUZZER 4 //PN_B3
#define Power_A 5 //PIN_B2
#define Power_B 6 //PIN_B1
#define ON 1
#define OFF 0
#define NO_DELAY 0
Int 16 adc_result;
Int channel_mov, channel _ photo, t;
Int8 ctr ;
Int8 value;
void outssignal(int8 signal_out,int8 state 1,int8 delay_ms1)
If signal _out==0)
If(state 1 ==0) output_low(PIN_B7); //pin40
else output_high(PIN_B7);
if(signal_out==1)
If(state1==0) output_low(pin_B6); //pin39
else output _high(pin_B6);
if(signal_out==2)
If(state1==0) output_low(pin_B5); //pin38
else output _high(pin_B5);
if(signal_out==3)
If(state1==0) output_low(pin_B4); //pin37
else output _high(pin_B4);
if(signal_out==4)
If(state1==0) output_low(pin_B3); //pin36
else output _high(pin_B3);
if(signal_out==5)
If(state1==0) output_low(pin_B2); //pin35
if(signal_out==6)
If(state1==0) output_low(pin_B1); //pin34
else output _high(pin_B1);
delay_ms(delay_ms1);
//main function
main()
set_tris_A(0b11111111);
setup_adc(ADC_CLOCK_INTERNAL);
setup_adc_ports(RA0_ANALOG); //setup_adc_ports(RA0
t=20;
printf(Start\r\n
