Home Community
Re: 0-12 Volts LM317 PSU
Welcome, Guest. Please login or register.
May 19, 2013, 04:39:28 PM
Home Help Search Calendar Login Register
News: trade your components on this new board: "Components trade"
Advertisements
No New Posts
Today at 01:39:33 AM
in
Advertisements
by google
+  Electronics-Lab.com Community
|-+  Electronics Forums
| |-+  Electronic Projects Design/Ideas (Moderators: Dazza, gogo2520, Herman the German)
| | |-+  Re: 0-12 Volts LM317 PSU
« previous next »
Pages: [1] Print
Author Topic: Re: 0-12 Volts LM317 PSU  (Read 3436 times)
ashishamours
Newbie
View Profile Email
« on: July 22, 2009, 10:37:32 PM »
hey friends,
i m  in need of a variable power supply (0-12v) , using lm317, n current booster ,hv output capacity of 1.5a.
 plz tell me if u can....
Logged
gogo2520
Electronics God
If I were smart I wouldn't have to study so hard
View Profile
« Reply #1 on: July 22, 2009, 11:07:39 PM »
hello ashishamours
   The lm317 to 220 package will handle a 1.5amp. If you need more try the lm350 to-3 package that will handle 3 amps.
                                                 gogo
Logged
audioguru
Electronics God
Gender: Male
I'm a theory expert! $crooge and I are thrifty.
View Profile
« Reply #2 on: July 23, 2009, 07:41:45 AM »
The lm317 TO-220 package will handle a 1.5amp.
Not when it has 15V across it because then it will be too hot and a huge heatsink and a fan might not help.
Logged
gogo2520
Electronics God
View Profile
« Reply #3 on: July 25, 2009, 08:44:49 AM »
Hello
     Wounder why the data sheet doesn't say that
                                     gogo
Logged
Hero999
Global Moderator
Electronics God
View Profile
« Reply #4 on: July 25, 2009, 09:58:05 AM »
It does, for a start 1.5A is only guaranteed at (VIN-VOUT) ≤ 15V, see page 5.
And there's a graph showing the safe area protection, see page 6.
http://www.national.com/ds/LM/LM117.pdf
Logged
I also post at:
http://www.silicontronics.com
I do not answer private messages asking for help because no one else can: benefit from advice I may give or correct me if I'm wrong.
Please ask on the open forum if you have a question: if I know the answer, I'll be happy to help.
audioguru
Electronics God
Gender: Male
View Profile
« Reply #5 on: July 25, 2009, 11:10:02 AM »
If the output is 1V at 1.5A and the input is 18V then the power in the LM317 is (18V - 1V) x 1.5A= 25.5W.
The thermal resistance of the TO-220 case is 4 degrees per Watt and if the ambient temperature is 30 degrees C then the chip will be at (4 degrees x 25.5W) + 30 degrees= 132 degrees C. But its max allowed temperature is 125 degrees C.
Adding an electrical insulator will make the temperature of the chip higher.
A heatsink is not perfect (it also heats up) so the temperature of the chip will also be higher.
Logged
gogo2520
Electronics God
View Profile
« Reply #6 on: July 25, 2009, 07:51:13 PM »
Sorry
  I don't know were the 18 volts came from the original post shows a 12 volt input. I figured he would use a 12 volt transformer  to start with and then use the regulator to lower it. And that would of been (12 - 1) x 1.5 = 16.5W
 ( 4 degrees x 16.5) + 30 degrees = 96, well under the max allowed temperature. Ya but still hot.
                     gogo
Logged
audioguru
Electronics God
Gender: Male
View Profile
« Reply #7 on: July 25, 2009, 08:42:19 PM »
An LM317 with a 12V output needs an input of at least 15V.
I was mistaken when i thought the output should be 15V then the minimum input must be 18V.
A 12V transformwer has a peak voltage of 17V which is reduced to about 15VDC by the rectifiers and filter capacitor.
If the output is set to 1V then the LM317 will have 14V across it and will try to dissipate 21W.
You must include the thermal resistance of the heatsink and electrical insulator into your temperature calculation.
Logged
Hero999
Global Moderator
Electronics God
View Profile
« Reply #8 on: July 26, 2009, 08:34:03 AM »
This can be solved by using a centre tapped transformer and taking the power from the tap when the output voltage is set below a certain level. I'll post a schematic if you're interested.
Logged
I also post at:
gogo2520
Electronics God
View Profile
« Reply #9 on: July 26, 2009, 08:09:45 PM »
Thanks Guys
    I'm not real good at building power supplies, mine are pretty simple. When I need a good large one I would use a prebuilt by someone who has the right stuff to do it with.
    I think this fall I am actually going to break down and invest in a oscilloscope and study power supplies along with a lot of stuff.   The reason is because I am getting ready to retire and am going to need something to keep me busy, so why not a hobby I enjoy.
   When I see something I don't understand I tend to ask questions and I might be a little crude about it. Sorry about that.
    Yes Hero999 if you don't mind please your schematic for the center tap power supply.
                                     thanks again
                                        gogo
Logged
Hero999
Global Moderator
Electronics God
View Profile
« Reply #10 on: July 29, 2009, 04:31:24 AM »
This will work, when the output voltage is set to under 12V the power is drawn from the centre tap cutting the power dissipated by U1.
It's designed for a 15-0-15V transformer, for a 9-0-9V change the D2 to 6.2V.
Logged
I also post at:
Pages: [1] Print
« previous next »
Jump to:
Advertisements
No New Posts
in
Advertisements
by google
Login with username, password and session length
Powered by MySQL Powered by PHP Powered by SMF 1.1.18 | SMF © 2013, Simple Machines Valid XHTML 1.0! Valid CSS!
Search Site | Advertising | Add your link here | Contact Us | Android TV Box
Elektrotekno.com | Free Schematics Search Engine | Electronic Kits | Electronic Accessories
