Home Community
Triggering transistor via Iphone's audio output jack
Welcome, Guest. Please login or register.
May 25, 2013, 05:20:01 AM
Home Help Search Calendar Login Register
News: trade your components on this new board: "Components trade"
Advertisements
No New Posts
Today at 01:39:33 AM
in
Advertisements
by google
+  Electronics-Lab.com Community
|-+  Electronics Forums
| |-+  Projects Q/A (Moderators: gogo2520, Herman the German, Hero999)
| | |-+  Triggering transistor via Iphone's audio output jack
« previous next »
Pages: [1] Print
Poll
Question: How can i amplify very low audio voltage?
Which transistor should i use for iphone's audio output jack?   -0 (0%)
How to trigger a transistor from iphone's audio output jack?   -0 (0%)
Total Voters: 0
Author Topic: Triggering transistor via Iphone's audio output jack  (Read 700 times)
cmd1024
Guest
« on: March 30, 2012, 02:53:03 AM »
I want to trigger a transistor using iPhone's audio output jack. My goal is to turn off an LED(which is fed by an external +5V battery) by sending an audio signal from iPhone's output jack. At the beginning i thought it is easy but i encounter many problems. I tried to do it with a transistor but it seems the iPhone audio output is too weak even for a transistor.
I am confused every time i find different ideas. Let me be more precise, here are the facts:
1-) The output voltage of iPhone is very low, something like 300 mV
2-) The output is an audio signal
And here are the problems:
1-) How to amplify this voltage? I found some different ideas after some googling such as:
a-Using transformers. This guys says one needs micro-transformer
http://web.eecs.umich.edu/~prabal/pubs/papers/kuo10hijack-islped.pdf
b- Using capacitor. Here one guy is suggesting using a very simple circuit. I tried it didn't work:
Power LED from headphone jack
c- Using op-amp
Can you assist me a little bit about this?
2-) Do we need to rectify the audio signal?
Here is the circuit i was trying at the beginning. I thought it is simple. But the transistor is not triggering with the audio signal:
http://imageshack.us/photo/my-images/52/signcae.jpg/
Logged
Hero999
Global Moderator
Electronics God
View Profile
« Reply #1 on: March 31, 2012, 04:11:56 AM »
Your LED circuit already has a 5V supply and you want it to turn off, not on when the audio is present, so the transformer idea won't work.
My first question is why are you doing this?
Secondly, how long does the LED need to remain off for when audio is present?
You need more than one transistor to get enough amplification.
A simpler approach would be a comparator or logic gates.
Logged
I also post at:
http://www.silicontronics.com
I do not answer private messages asking for help because no one else can: benefit from advice I may give or correct me if I'm wrong.
Please ask on the open forum if you have a question: if I know the answer, I'll be happy to help.
Pages: [1] Print
« previous next »
Jump to:
Advertisements
No New Posts
in
Advertisements
by google
Login with username, password and session length
Powered by MySQL Powered by PHP Powered by SMF 1.1.18 | SMF © 2013, Simple Machines Valid XHTML 1.0! Valid CSS!
Search Site | Advertising | Add your link here | Contact Us | Android TV Box
Elektrotekno.com | Free Schematics Search Engine | Electronic Kits | Electronic Accessories
