i have a crappy gear selector that i want to change
i know what i want
i know how it should work
i know it will be safe
i don't know how to build the electronic
as you can see in the pic it's a simple design to keep it reliable
it uses the 12v acc power to power the unit but i'm thinking it might be better to use the 12 batt power to run the solenoids via internal or external relays, i'd prefer internal
the safety must be pressed or pulling the stock/modified shifter will do bugger all
i was thinking of two industrial momentary switches telling the what ever to fire off the solenoid, i also want the what ever to have a delay of 1-2 seconds before it can fire off the next solenoid so the box it not going to miss a gear and blow up, it's a light truck gear box but still it's $1500aud to repair
the what ever needs to fire to two solenoids in a specific order to go up and the same order in reverse to go back down
it's like a tip tronic/paddle shift system without the pagani zonda hanging off it
so i assume you are all still with me do you have any ideas how to make the what ever
and help would be awesome
