Home Community
negative ioniser
Welcome, Guest. Please login or register.
May 24, 2013, 09:23:19 PM
Home Help Search Calendar Login Register
News: trade your components on this new board: "Components trade"
Advertisements
No New Posts
Today at 01:39:33 AM
in
Advertisements
by google
+  Electronics-Lab.com Community
|-+  Related to Electronics
| |-+  High Voltage Stuff (Moderator: Hero999)
| | |-+  negative ioniser
« previous next »
Pages: [1] Print
Author Topic: negative ioniser  (Read 961 times)
keron
Jr. Member
Gender: Male
stay cool
drkarancool
View Profile Email
« on: May 30, 2012, 09:33:50 AM »
Hi all,
I am looking for a circuit that operates in 9-12 DC and will generate voltage in 2-3KV range with negiligible current. I came across many designs but interested if anyone knows any circuit that uses common step down transformer with primary and secondary reversed as the first step in conversion.I am planning to use Cockcroft–Walton multiplier to increase the voltage from transformer. Flyback transformers are difficult to find /not familar for me to use.But would defenitely consider if its readily available
I came across this circuit and like to know if something similar can be tried with a step down transformer
http://www.aaroncake.net/circuits/flampdrv.asp
If anyone know any schematic with small flyback transformers I would be glad to try.I am only concerened about availability.
The whole purpose is to make a negative ion generator to clean dust from my vinyls. I donot want to use the ones based on Pizo electric but somehing that will generate a massive negative ion flow that will neutralize all sticky dust on my LPs
.The prime consideration is making it as small as possible.
Logged
Hero999
Global Moderator
Electronics God
View Profile
« Reply #1 on: May 30, 2012, 10:42:47 AM »
The same basic blocking oscillator circuit, normally used to drive a flyback transformer, can also drive a centre tapped or dual primary mains transformer.
Here's an example of a capacitor charger using a mains transformer with a centre tapped primary. It should be able to drive a voltage multiplier circuit.
Code:
                    C1 1 uF                   D2 1N4948   R2
                 +------||------+        T1    1.2kV PRV  1K 1W
                 |              |           +-----|>|-----/\/\---+------o +
                 | R1 4.7K, 1W  |   red  ||( blk                 |
                 |                  yel )||(                   +_|_ C2
  + o----------------------------------+ ||(                    --- 300 uF
                 |                  red )||(                   - |  450 V
                 |  Q1  |                ||( blk                 |
 6 to 12         |    |/ C                  +--------------------+------o -
 VDC, 2A         +----|    2N3055    Stancor P-6134
             D1 _|_   |\ E           117 V Primary (blk-blk)
         1N4007 /_\     |            6.3 VCT Secondary (red-yel-red)
  - o------------+------+
http://www.repairfaq.org/sam/samschem.htm#schssi
Logged
I also post at:
http://www.silicontronics.com
I do not answer private messages asking for help because no one else can: benefit from advice I may give or correct me if I'm wrong.
Please ask on the open forum if you have a question: if I know the answer, I'll be happy to help.
keron
Jr. Member
Gender: Male
stay cool
drkarancool
View Profile Email
« Reply #2 on: May 31, 2012, 02:55:40 PM »
 Grin Thank you hero. do you think the original circuit for CFL inverter would work ok? or the latter one is best  Roll Eyes.
How much voltage should be there at the tip of the needle to make those dust particle neutral?
Logged
Hero999
Global Moderator
Electronics God
View Profile
« Reply #3 on: May 31, 2012, 04:22:23 PM »
I don't know which circuit will work best for you, try them both.
Logged
I also post at:
Pages: [1] Print
« previous next »
Jump to:
Advertisements
No New Posts
in
Advertisements
by google
Login with username, password and session length
Powered by MySQL Powered by PHP Powered by SMF 1.1.18 | SMF © 2013, Simple Machines Valid XHTML 1.0! Valid CSS!
Search Site | Advertising | Add your link here | Contact Us | Android TV Box
Elektrotekno.com | Free Schematics Search Engine | Electronic Kits | Electronic Accessories
