Home Community
Opto Coupler Common Ground
May 19, 2013, 01:39:31 AM
Advertisements
No New Posts
Today at 01:39:33 AM
in
Advertisements
by google
|-+  Electronics Forums
| | |-+  Opto Coupler Common Ground
« previous next »
Pages: [1] Print
Author Topic: Opto Coupler Common Ground  (Read 380 times)
xenobie
Newbie
View Profile
« on: April 03, 2012, 01:39:11 PM »
Hi Guys,
As I understand opto couplers, their main use is to isolate a circuit from another,mainly for protection purposes. In my case I have an Arduino which controls a couple of shift registers (74HC595) which trigger transistors and I would like to protect the Arduino and the Shift Registers from any damage.
Since the Arduino works with 5V, and the Transistors will be switching 12 - 14VDC, BOTH INPUT and OUTPUT will be using the same ground. My question is this. Does it make sense to use an opto coupler since I will be using the same Ground? I mean is there any protection at all?
Some more info on the power source:
The main power source is going to be a car battery OR an ac transformer converted to DC. For the Arduino I am going to get this voltage and stabilise it using a 7805.
Thanks a lot  Cool
Logged
Hero999
Global Moderator
Electronics God
View Profile
« Reply #1 on: April 03, 2012, 05:47:09 PM »
There is no point in using an opto-coupler, if both circuits use the same ground.
Logged
I also post at:
http://www.silicontronics.com
xenobie
Newbie
View Profile
« Reply #2 on: April 04, 2012, 01:13:22 AM »
That's what I thought.. so is there any other way to protect your circuitry apart from using opto couplers and  2 different supplies? I must use only 1 car battery.
Thanks for your reply too Smiley
X
Logged
Pages: [1] Print
« previous next »
Jump to:
Advertisements
No New Posts
in
Advertisements
by google
