Hi, I’m currently onto some small personal project of mine that I thought of just messing around with but don’t have the knowledge, so I’m hoping that I would get some help here with it.
I have a non-toggle switch (like a lighter, you need to press and hold for a continuous flow of flame) that connects to a strip of LED (no flashing), run by 12V battery.
Now, I want to modify it that if I press and hold ON onto the switch for more than 7 seconds, it will start flashing at 1Hz. The flashing will only stop if I let go of the switch, but shall immediately “reset” into normal again. (will not flash unless until 7 seconds again)
Now a tricky one;
Another set (I have a non-toggle switch (like a lighter, you need to press and hold for a continuous flow of flame) that connects to a strip of LED (no flashing), run by 12V battery.)
Now, I want this set to flash at 4Hz for 4 seconds once “Poke” ON onto the switch. I realise this is quite difficult as it also means there must be some “reserve” energy for this to happen. I just have to “Poke” or “Tab” the switch and it will flash for 4 seconds.
Can anyone help me with this, please?
