Home Community
power problem
May 24, 2013, 02:48:15 PM
Advertisements
No New Posts
Today at 01:39:33 AM
in
Advertisements
by google
|-+  Electronics Forums
| |-+  Power Electronics (Moderators: Gazza, Hero999)
| | |-+  power problem
« previous next »
Pages: [1] Print
Author Topic: power problem  (Read 1194 times)
qwetie
Newbie
View Profile Email
« on: April 19, 2012, 03:00:07 PM »
hello there,
i have a power problem that is proving difficult to solve with my limited electronics knowledge , i have a single rail psu for my project box and need to power three ICs , one IC needs dual rail and the other two can run from single rail.
i have a electret mic connected to an op amp (TL071), then to a line balancing IC(DRV134) for sending to a mixer. there is also a VU meter (lm3915)attached to the op amp output.
each of the ICs circuits work well, but when i try to connect the single rail to a floating ground dual rail , its not happy at all.
i am trying to figure out how to power all these things so they can connect together without strange ground loop issues.
here is a schematic to aid explaination, ive taken out the power wires so its not so cluttered, and i've highlighted the power and ground connections with red and green dots.
hope you can help : )
Logged
Hero999
Global Moderator
Electronics God
View Profile
« Reply #1 on: April 20, 2012, 11:34:01 AM »
I'm sure you ca  figure this out for yourself.
Hint: the floating ground behaves like a 6V voltage source, in series with two 4k7 resistors connected in parallel.
Logged
I also post at:
http://www.silicontronics.com
ccsintlcircuits
« Reply #2 on: June 06, 2012, 03:50:55 AM »
Some of the people  facing problem of power and their problem .There are many services problem provide in this post which shown the various solutions for the people .
Logged
KevinIV
Electronics God
Gender: Male
View Profile
« Reply #3 on: June 06, 2012, 07:01:16 PM »
IC's which utilize dual polarity supply voltages are intended to ouput positive and negative voltage. The IC supply voltage must be connected to the rest of your circuit power. Since these IC's utilize ground in most cases, additional circuitry would be needed. It's not simple and it is inefficient design.
Logged
alyna
« Reply #4 on: July 23, 2012, 09:52:29 PM »
can someone answer me about what causes power problem? Smiley
Logged
Pages: [1] Print
« previous next »
Jump to:
Advertisements
No New Posts
in
Advertisements
by google
