Home Community
Eletronic stethoscope but different intent!
Welcome, Guest. Please login or register.
May 20, 2013, 02:24:55 PM
Home Help Search Calendar Login Register
News: trade your components on this new board: "Components trade"
Advertisements
No New Posts
Today at 01:39:33 AM
in
Advertisements
by google
+  Electronics-Lab.com Community
|-+  Electronics Forums
| |-+  Electronic Projects Design/Ideas (Moderators: Dazza, gogo2520, Herman the German)
| | |-+  Eletronic stethoscope but different intent!
« previous next »
Pages: [1] Print
Author Topic: Eletronic stethoscope but different intent!  (Read 713 times)
D Ryan
Newbie
View Profile
« on: April 19, 2012, 06:04:04 PM »
This is my first post! I am new to electronic's, I have a radio shack learning lab, only done a few things with that!
Would this project be a good one for my learning lab?
http://www.electronics-lab.com/projects/science/003/index.html
Most of the threds I have read are member wanting to detect heart beat!
What I have in mind is a little different I don't know if it can be done the way I want it to.
I want to detect the clicking of a fuel injector coil going off an on! I don't want to listen , just the LED blink is fine.
In the plans there shows a OPTION to add LEDS! Could I just build that and eliminate the head phone part of the plans?
I would also like to have a prob to reach into a running engine and touch hard to reach injectors for the sound pickup.
Any help with this?
Logged
Hero999
Global Moderator
Electronics God
View Profile
« Reply #1 on: April 20, 2012, 11:37:42 AM »
This circuit won't differentiate between one sound and another, that's much more difficult to do.
It sounds like you're doing it the hard way. Why not connect an LED and resistor across the injector coil, or if you don't want to make physical connection, use a coil to detect the injector coil's field.
Logged
I also post at:
http://www.silicontronics.com
I do not answer private messages asking for help because no one else can: benefit from advice I may give or correct me if I'm wrong.
Please ask on the open forum if you have a question: if I know the answer, I'll be happy to help.
D Ryan
Newbie
View Profile
« Reply #2 on: April 20, 2012, 03:15:15 PM »
 From the circuit descritpion:
• U1b operates as a low-noise Sallen and Key, Butterworth low-pass-filter with a cutoff frequency of about 103Hz. R7 and R8 provide a gain of about 1.6 and allow the use of equal values for C3 and C4 but still producing a sharp Butterworth response. The rolloff rate is 12dB/octave. C3 and C4 can be reduced to 4.7nF to increase the cutoff frequency to 1KHz to hear respiratory or mechanical (automobile engine) sounds.
 I have a sepehoscope from harbor freight I can just place it on the running injector and hear it "snap" on problem!
I dont like wearing it around moving parts and 100K volts!!
Some of these injectors are hard to get to! Infact some engine dis-assembly is required to get to them, and thats just to check them for mechanical movement. Doing this with a prob using sound or light short-cuts this whole process, for the shade tree DIY'er!
I did some experment today with a earphone,I hooked the ear phone to my meter and a red LED , when I tapped the earphone the LED blinked dimmly and got a reading of about 29.0 MV, AC. Tap  was more like a slap!
Thanks for your thoughts!
Logged
Hero999
Global Moderator
Electronics God
View Profile
« Reply #3 on: April 20, 2012, 06:11:46 PM »
I know it can pick up engine sounds. My concern is that the flashing LED part may not work as there are many harmonics given off by the engine. If you just want to listen, then fine but don't expect it to be able to flash the LED every time the injector fires.
Quote
Fuel injectors are powered off 12V. The only high voltage present in a car is the ignition system and is typically no more than 10kV.
Quote
You've got your prefix wrong there, you mean 28mV which is just 0.028V which is nothing, and you must've got the decimal place wrong as it isn't enough light an LED.
Logged
I also post at:
D Ryan
Newbie
View Profile
« Reply #4 on: April 20, 2012, 06:39:38 PM »
Quote
Quote
I tryrd it again, this time I used a min-max meter! 79.4 MV AC, Led light every time!
I see what your saying! The circuit will recieve any signal and light the LED. Maybe some kind of sensativity can be added to it.
Also noticed the harder I hit the earphone , the more voltage, and of course the brighter the light!
Here is a picture of a fuel injector sound wave, it might be that there will be light on the LED at all times but only brighter light when pintel snaps. Just guessing!!
 Right now I'm trying to figure a wat to bench test this theory!! Any idea's!
http://ecomodder.com/forum/member-superturnier-albums-injector-opening-delay-picture2854-injector-voltage-signal-injector-sound-signal-resolution-between.html
That Link has 3 pictures in it!  I only assume that the recording on the meter is while the engine is running! The 3rd pic showes a piezo-ele device attcheted!
I'm beginning to think that my choice of circuits to build is a poor one!!
Denny
Logged
Hero999
Global Moderator
Electronics God
View Profile
« Reply #5 on: April 21, 2012, 04:10:51 AM »
Wrong prefix again, 79.9MV is 7990 000V, 79.9mV is only 0.079V
http://en.wikipedia.org/wiki/Metric_prefix
An  LED needs at least 1.8V to work. My guess is the actual peak voltage is more like 3V but it's so brief your meter doesn't have time to respond to it. If you connected it t an oscilloscope, you'd probably see a 3V pulse.
Don't forget this is with you tapping the ear phone so the voltage will be much higher than if you were to place t next to a noisy object.
Logged
I also post at:
D Ryan
Newbie
View Profile
« Reply #6 on: April 21, 2012, 10:26:46 AM »
Thanks Hereo999
Again I hooked it up to the Fluke 116, this time to auto Loz, I got no reading at all but the LED would flash! So it has to be to fast for the read!
Thanks again
Logged
Pages: [1] Print
« previous next »
Jump to:
Advertisements
No New Posts
in
Advertisements
by google
Login with username, password and session length
Powered by MySQL Powered by PHP Powered by SMF 1.1.18 | SMF © 2013, Simple Machines Valid XHTML 1.0! Valid CSS!
Search Site | Advertising | Add your link here | Contact Us | Android TV Box
Elektrotekno.com | Free Schematics Search Engine | Electronic Kits | Electronic Accessories
