Home Community
propblem with RS232 to RS485 Pleased help!
Welcome, Guest. Please login or register.
June 19, 2013, 08:49:21 PM
Home Help Search Calendar Login Register
News: trade your components on this new board: "Components trade"
Advertisements
No New Posts
Today at 01:39:33 AM
in
Advertisements
by google
+  Electronics-Lab.com Community
|-+  Electronics Forums
| |-+  Electronic Projects Design/Ideas (Moderators: Dazza, gogo2520, Herman the German)
| | |-+  propblem with RS232 to RS485 Pleased help!
« previous next »
Pages: [1] Print
Author Topic: propblem with RS232 to RS485 Pleased help!  (Read 494 times)
anhnha
Newbie
View Profile
« on: April 26, 2012, 03:46:07 AM »
Hi all,
I had do the circuit like that.But I wire up in breadboard it is not work.In my project I need to communicate between computer(COMM PORT) and micro.But now I want to check 2 circuits that I had wire in breadboard:
-the first breadboard for RS232 to RS485
-the second breadboard for RS485 to RS232
in reality, I need 2 computers to communicate but now have only one therefore I used TX pin of comm port to transmit and also used RX of this port to receive data.
Because I only used on computer thus I had connect TX of comm port to 232 input of one breadboard and RX of comm port to 232 output of the other breardboard.And then I used the program i posted above to transmit and receive data from comm port.But when I am not use 5 Voltage connected to ICs and I supprised due to is read from comm port is exact but when power is connected then it is not work.At first I think that it receiced data may be TX and RX is connected to each other but when i used ohm meter to measure the resistance between TX and RX, i received the value is very large and this mean it is not connected.I am confused why it is not connected but i can received data and when power is connnected it is not work.
I have checked all connected in breadboard, all of them are good.Would you give me how to solved it,i have wire up the circuit in breadboard many times but all are the same.Finally I can not to transmit between two computer.Will i need add something in this circuit in reality?Are there anything wrong in my schematic?
would you help me check it.I have attach my file in this
And this is orginal circuit that i used:
http://www.bb-elec.com/bb-elec/literature/485ptbr-3903ds.pdf
Logged
Hero999
Global Moderator
Electronics God
View Profile
« Reply #1 on: April 26, 2012, 05:33:17 AM »
None of your links work.
Logged
I also post at:
http://www.silicontronics.com
I do not answer private messages asking for help because no one else can: benefit from advice I may give or correct me if I'm wrong.
Please ask on the open forum if you have a question: if I know the answer, I'll be happy to help.
anhnha
Newbie
View Profile
« Reply #2 on: April 26, 2012, 09:39:29 AM »
I am sorry.I have just attach the schematic and the orginal circuit i used to built:
Would you take a look it and help me with this confusion.
Thanks in advance.
Logged
Pages: [1] Print
« previous next »
Jump to:
Advertisements
No New Posts
in
Advertisements
by google
Login with username, password and session length
Powered by MySQL Powered by PHP Powered by SMF 1.1.18 | SMF © 2013, Simple Machines Valid XHTML 1.0! Valid CSS!
Search Site | Advertising | Add your link here | Contact Us | Android TV Box
Elektrotekno.com | Free Schematics Search Engine | Electronic Kits | Electronic Accessories
