Home Community
What is a reasonable frequency?
Welcome, Guest. Please login or register.
June 18, 2013, 10:52:46 PM
Home Help Search Calendar Login Register
News: trade your components on this new board: "Components trade"
Advertisements
No New Posts
Today at 01:39:33 AM
in
Advertisements
by google
+  Electronics-Lab.com Community
|-+  Electronics Forums
| |-+  Theory articles (Moderator: redwire)
| | |-+  What is a reasonable frequency?
« previous next »
Pages: [1] Print
Author Topic: What is a reasonable frequency?  (Read 1798 times)
KevinIV
Electronics God
Gender: Male
View Profile
« on: February 23, 2004, 04:14:59 PM »
What is the maximum frequency that is reasonable to work with?Something that can be averaged to a DC level and measured with a meter.
Logged
MP
Electronics God
30+ Years Engineer
View Profile
« Reply #1 on: February 23, 2004, 08:11:01 PM »
what do you mean by reasonable?
Do you mean parts availability? Ease to build a circuit? Component count?
Converting an AC signal to a DC signal is as easy as rectifying it and adding a few bypass caps. This is pretty much standard throughout the frequency range.
MP
Logged
KevinIV
Electronics God
Gender: Male
View Profile
« Reply #2 on: April 03, 2004, 05:56:58 PM »
I am looking for a frequency that is not too high. I think the oscillator circuits get too clumsy at higher frequencies. I know that the transistors exhibit strange properties at higher frequencies, but how high. There is bound to be a graph that shows this. Anything that produces variability makes it harder to get the design right. I would say somewhere in the Khertz is the most reliable. I need the designs to stay simple and predictable. The oscilloscope isn't the only device with which to measure accuracy.
Logged
Ldanielrosa
Sr. Member
Gender: Male
I'm a Ttibetan ppreist!
View Profile
« Reply #3 on: April 04, 2004, 01:48:46 AM »
It depends on what you're using it for.  If it's for PWM control of a motor, then 1kHz may serve you.  It can be divided from most oscillator crystals that are likely to be used with uCs (sorry, lazy- didn't look for the code for 'mu').
Logged
What is truth, and what is fact?
A truth is what you live or die by.
A fact can save or kill you.
sec
Newbie
I'm a llama!
View Profile
« Reply #4 on: April 04, 2004, 04:18:36 AM »
Sorry, but without more information about what you're trying to do, we can't really give you a good answer.
As for transistors, they will all have a maximum frequency for which they're good.  This depends on the model of transistor, and can range from a few kilohertz to a few gigahertz.  You'll need to check the transistor's datasheet to find out for sure.
Almost any integrated circuit will have some kind of maximum frequency that they will be rated for.  Be careful, though, since sometimes this parameter is lumped together with other parameters.  For example, op-amps have a parameter called slew rate, which is usually measured in V/uS.  This tells you how much change in voltage the op-amp can deal with in a given time frame.  What this means is that the greater the voltage swing the op-amp has to deal with, the lower its maximum frequency will be.
Another thing you have to worry about at high frequencies is that for simplicity's sake, we usually model the wires connecting the components as perfect conductors.  At low frequencies, this is a good approximation, but at high frequencies, if you don't model the capacitances and inductances associated with the conductors, you'll get wildly inaccurate results.  Needless to say, this complicates modelling drastically.  Read up on transmission line theory for an overview of the issues involved.
That said, I have naively (that is, without taking special measures for dealing with high frequencies) built digital logic circuits up into the mid-single-digit megahertz range, without any ill effects.  Not so sure about analog circuits, as I've never built anything beyond about 100 KHz.  I would assume that high-frequency effects would start being noticeable in analog circuits before they would be in digital circuits, as in the latter, the effects would have to be large enough to start flipping bits before they would become noticeable.
Logged
KevinIV
Electronics God
Gender: Male
View Profile
« Reply #5 on: April 04, 2004, 12:04:23 PM »
The high frequency aspects of the inductances and capacitances are something I don't want to deal with. You must also know the characteristic of your measuring device. This will be a bridge or simple circuit. The final measurement device will be a DC meter or AC meter. Can I safely say that 10Ghertz is too high and 1 hertz is too low? Maybe the time difference isn't so great given the relativity of things. You will notice that high frequency networks deal of capacitors and inductors that are of reasonable size.
Logged
Pages: [1] Print
« previous next »
Jump to:
Advertisements
No New Posts
in
Advertisements
by google
Login with username, password and session length
Powered by MySQL Powered by PHP Powered by SMF 1.1.18 | SMF © 2013, Simple Machines Valid XHTML 1.0! Valid CSS!
Search Site | Advertising | Add your link here | Contact Us | Android TV Box
Elektrotekno.com | Free Schematics Search Engine | Electronic Kits | Electronic Accessories
