Home Community
Datasheet for 3038 fuction generator
Welcome, Guest. Please login or register.
May 23, 2013, 01:54:05 AM
Home Help Search Calendar Login Register
News: trade your components on this new board: "Components trade"
Advertisements
No New Posts
Today at 01:39:33 AM
in
Advertisements
by google
+  Electronics-Lab.com Community
|-+  Electronics Forums
| |-+  Datasheet/Parts requests (Moderators: hotwaterwizard, Herman the German)
| | |-+  Datasheet for 3038 fuction generator
« previous next »
Pages: [1] Print
Author Topic: Datasheet for 3038 fuction generator  (Read 1497 times)
Alun
Guest
« on: September 07, 2005, 08:54:00 AM »
Please can I have the datasheet for the 3038 function generator project. I'd like to know the formulas used to design this circuit so I can re-design it to suit my needs and hopefully make it better too. Thanks.
Logged
audioguru
Electronics God
Gender: Male
I'm a theory expert! $crooge and I are thrifty.
View Profile
« Reply #1 on: September 07, 2005, 10:23:20 AM »
Hi Alun,
www.datasheetarchive.com call this an obsolete product. Years ago Intersil had some pretty good application notes about this IC. Grin
http://www.datasheetarchive.com/semiconductors/download.php?Datasheet=933735
Logged
Alun
Guest
« Reply #2 on: September 07, 2005, 11:07:59 AM »
I had a feeling this was the case Sad is there a sutable equivalent IC or some other simple way of building this signal generator?
Logged
audioguru
Electronics God
Gender: Male
View Profile
« Reply #3 on: September 07, 2005, 11:55:57 AM »
Hi Alun,
Maxim have an extremely expensive one that goes up to 20MHz, MAX038.
EXAR had theirs but don't make it anymore.
I made and have 3 sine-wave generators:
1) A Wien bridge with a calibrated frequency dial and a dual tuning capacitor from an old tube (valve) AM radio. Its output bounces when the frequency is changed and its response drops off a bit at both ends of the dial because I couldn't match its 40M resistors and capacitance of the range switch very well.
2) An extremely low distortion oscillator that I designed to have a variable frequency, but its PLL caused phase jitter that ruined its low distortion. It has a CD4018 as a stepped sine-wave maker followed by a switched-capacitor 4-stage Butterworth lowpass filter IC.
I now use it with a fixed frequency but its frequency could be changed with a single pot with a switch selecting its decades. Its distortion at the high end of each range would be fairly low.
3) A phase-shift oscillator with a very stable output level, fairly low distortion and frequencies from 20Hz to 2kHz, and 200Hz to 20kHz. I had to use a triple gang pot from a RadioShack thingy and luckily it had 4 of them for me to select the one with the best tracking. I had to order a fairly high frequency (37MHz GBP) MC33077 dual opamp for it 'cause an MC33172 opamp had way too much phase shift at 20kHz. Even an MC34072 wasn't good enough.
Fairchild has a fairly new sine-wave generator IC. Its output supposedly looks like and sounds like it has very low distortion but measuring it shows its conflict in its phase-accumulator. Its output is very stable.
Interested in a schematic? Grin
Logged
Alun
Guest
« Reply #4 on: September 07, 2005, 02:17:29 PM »
I was concerned I'd have to build something as complex as 1 & 2, I did consider 3 but I don't have any triple ganged pots, can you still buy these?
Luckily I've found an old 3038 lying around at work, but I'm still very  interested in fairchild's IC (and any other possible alternatives) though just in case the IC I've found is a dud.
Logged
hotwaterwizard
Electronics God
Gender: Male
Service Tech
hotwaterwizard hotwaterwizard hotwaterwizard
View Profile WWW Email
« Reply #5 on: September 07, 2005, 11:29:58 PM »
http://www.web-ee.com/Schematics/Function%20Generator/function%20generator.htm
Logged
John DeRosa (Hotwaterwizard)
When in Doubt, Try it out!!
Alun
Guest
« Reply #6 on: September 08, 2005, 03:49:32 AM »
Thanks hotwaterwizard, it look like I might have to do some more design work to get this working to my specfication but good idea none the less, do you know where you can buy the MAX038 IC from? Note I live in the UK.
Logged
audioguru
Electronics God
Gender: Male
View Profile
« Reply #7 on: September 08, 2005, 09:32:06 AM »
Hi Alun,
If you are nice to Maxim, they might ship you a free sample. Grin
Logged
hotwaterwizard
Electronics God
Gender: Male
Service Tech
« Reply #8 on: September 08, 2005, 10:47:52 PM »
Exactly what are you trying to do?
CHECK OUT THIS!
http://www.digisound80.co.uk/digisound/modules/80-18/80-18.htm
Logged
Alun
Guest
« Reply #9 on: September 09, 2005, 01:44:48 PM »
I want to build a reasonable quality sine wave generator variable from 10Hz to at least 100kHz (the higher the better). This frequency range is very useful for testing audio amplifiers,even though the high frequencies are abouve the human hearing range they are still very useful as you can see phase shifts which occur at these frequencies  and can  cause instability and oscillation.
Logged
Pages: [1] Print
« previous next »
Jump to:
Advertisements
No New Posts
in
Advertisements
by google
Login with username, password and session length
Powered by MySQL Powered by PHP Powered by SMF 1.1.18 | SMF © 2013, Simple Machines Valid XHTML 1.0! Valid CSS!
Search Site | Advertising | Add your link here | Contact Us | Android TV Box
Elektrotekno.com | Free Schematics Search Engine | Electronic Kits | Electronic Accessories
