Home Community
Led display Digital Voltmeter question
Welcome, Guest. Please login or register.
May 25, 2013, 01:38:21 PM
Home Help Search Calendar Login Register
News: trade your components on this new board: "Components trade"
Advertisements
No New Posts
Today at 01:39:33 AM
in
Advertisements
by google
+  Electronics-Lab.com Community
|-+  Electronics Forums
| |-+  Projects Q/A (Moderators: gogo2520, Herman the German, Hero999)
| | |-+  Led display Digital Voltmeter question
« previous next »
Pages: [1] 2 3 ... 24 Print
Author Topic: Led display Digital Voltmeter question  (Read 75438 times)
bonanz
Newbie
I'm a llama!
View Profile
« on: November 12, 2003, 04:01:21 AM »
This circuit came up at the perfect time! couldnt have asked for a more perfect design for what i need right now, only problem is i don't have a -5 volt supply.  What would happen if i grounded that pin rather than using -5.  would that simply not allow for negative voltages to be measured? because i only need positive for my application. or is there a simple way to make a negative supply from only a +5 being available?
thanks
bonanz
Project Link: http://www.electronics-lab.com/projects/test/001/index.html
Logged
gsmaster
Jr. Member
Gender: Male
User terminated by software.
View Profile WWW
« Reply #1 on: November 12, 2003, 04:54:04 AM »
You can use the TC7660 (from microchip I think Huh) which is for this job. It takes gnd and +5V and gives you your -5V. Wink
Logged
mixos
Administrator
Electronics God
Gender: Male
View Profile WWW
« Reply #2 on: November 12, 2003, 08:00:07 AM »
If you ground -5V pin, and apply +5V to the pin 3 then it will work nice  Cheesy  for measuring positive voltages (i already tried it). I am not sure what will happen with negative voltages, i haven't tried it.
Hope that helps a bit.
Logged
bonanz
Newbie
I'm a llama!
View Profile
« Reply #3 on: November 12, 2003, 02:07:42 PM »
okay great, because i only need the circuit to measure positive voltages, the input will never go negative. when you say pin 3 do you mean pin 3 on the pcb? not on the chip right?
Logged
mixos
Administrator
Electronics God
Gender: Male
View Profile WWW
« Reply #4 on: November 12, 2003, 04:32:11 PM »
Right... the pin 3 that is indicated with +5V at schematic.
Logged
mozikluv
Newbie
Gender: Male
~balut pinoy "?-
View Profile
« Reply #5 on: November 17, 2003, 11:32:12 PM »
 :)hi bonanz,
you said you would be measuring only positive voltages, now what would happen if you accidentally reverse your probe. wont your voltmeter get burned? i believe one of the reson why this device was designed to have a dual supply is bcoz of that. if you reverse the probe your display will have a negative sign.
since you said you only have a 5v positive supply, try using LM7905 to get a 5v negative supply.
hope this solves your problem.
Logged
mozikluv
Newbie
Gender: Male
~balut pinoy "?-
View Profile
« Reply #6 on: November 18, 2003, 07:06:33 AM »
 :)hi bonanz,
sorry i was not able to complete my reply, one way to solve your -5v swupply source is to use a 10v transfo. this is how you do it,
1. series 2 resistors
2. shunt the resistors across the rectified output
3. from the junction of the 2 resistors, this is where you tap your ground
4. connect the usual filters
5. connect your 7805 for +5v and 7905 for -5v
suggested resistance value is 47K 2w
hope you can benifit from this Smiley
Logged
bonanz
Newbie
I'm a llama!
View Profile
« Reply #7 on: November 27, 2003, 12:10:13 AM »
Okay i've done some playing around with this circuit and i cannot get it to work for my application.  I'm not worried about switching terminals because i am not using it as a typical dmm i'm using it to display a voltage in a circuit that will always be positive.  I am using the LM2907 frequency to voltage converter and have it convigured so that the output voltage is linearly proportional to the input frequency (ie 200mv ~ 200hz) the max freqency i'd measure would be about 1200Hz which would correspond to 1.2v work perfectly on the 2v scale and i would just leave the decimal points unconnected.  I have hooked up the project circuit, and did a test on a voltage divider to see if it was measuring correctly and it did measure the voltage, but i only had to connect terminal one to the voltage point and did not connect terminal 2 to anything and the voltage displayed correctly. (this is btw with the negative supply grounded).  The LM2907 freq to voltage converter circuit i have completely working and outputing the corresponding voltage when i use a regular multimeter, but i would like to integrate this circuit with it to have a permanent display. any help would be appreciated.
bonanz
Logged
billy
Full Member
Gender: Male
View Profile
« Reply #8 on: December 28, 2003, 06:19:04 AM »
I would really appreciate if someone could tell me a way to change the default 0-2,0-20,0-200,0-2000 scales to a custom one, for example
0-30 V (or 0-40, it doesn't matter)
because I want to integrate this circuit to the Stabilized 0-30V 0-3 A Power Supply that appears on the entry page of this site. I am about
to design a new PCB with a complete solution for a lab PSU.
Thanks !  Smiley
Logged
mixos
Administrator
Electronics God
Gender: Male
View Profile WWW
« Reply #9 on: December 28, 2003, 07:38:21 AM »
I use this digital voltmeter with this
3-30V power supply: http://www.electronics-lab.com/projects/power/032/index.html
If you configure it at 200V range (R3 = 12K) then it will measure from 0-30V with one decimal point precision.
for   4,1V will display: X04.1
for 10,1V will display: X10.1
where X indicates that the first display is OFF
I think this configuration is ideal for your power supply.
If you finally draw a PCB for a complete bench PSU solution i will be happy to host it under the power supply's page  Wink .
Logged
MP
Electronics God
30+ Years Engineer
View Profile
« Reply #10 on: December 28, 2003, 09:55:08 PM »
I have not yet tried this, but one should be able to have auto ranging with comparators and a 4066 cmos switch.
MP
Logged
billy
Full Member
Gender: Male
View Profile
« Reply #11 on: January 03, 2004, 05:11:41 AM »
I tried to build the L.D.D.V. yesterday, using a breadboard and
I came up with peculiar readings on the LEDs.  Huh I had followed the
schematic from smartkit.
I thought that I had a false ICL7107 and I dismounted the
components.  Embarrassed
Today I thought to check the data sheets of ICL7107 and MAN6960 in order to cross-check the connections. Found inconsistencies in the
article schematic !  Angry
For example for the 1's display :
Article : ICL(6) -> MAN(10)
Should be : ICL(6) -> MAN(9)
another example :
Article : ICL(34)
Should be ICL(25) -> MAN(1) and so on... there are many there.
Moreover, the R1 should be 100K, not 180K, I refer to the datasheet
and the "Digital Voltmeter" project
Finally, the LCD dot, is pin number 5, emitted in the schematic.
I am about to search all the errors now and report back later,
after I will rebuild the voltmeter.
I attach the data sheets for further reference.  Cool
Logged
MP
Electronics God
30+ Years Engineer
View Profile
« Reply #12 on: January 03, 2004, 01:19:59 PM »
Billy, I look forward to your findings when you are finished. I had planned to use this circuit as part of a larger project. Glad you found the bugs in it. I had also downloaded the data sheets, but I had not yet compared them with the project schematic. Good find!
MP
Logged
mixos
Administrator
Electronics God
Gender: Male
View Profile WWW
« Reply #13 on: January 03, 2004, 01:35:57 PM »
Great Work Billy. Thanks for doing that  Cheesy .
Sometime ago an internet friend told me that the kit companies are making some small faults (not by chance) on schematics to prevend them from copying  Shocked ! If you relly on the PCB, everything will work nice, becuase it's a copy of the original (already worked) board. So you can use it to debug the schematic.
Please do the debuging and make the changes to the schematic... i will be very happy to see it here!
Logged
« previous next »
Jump to:
Advertisements
No New Posts
in
Advertisements
by google
Login with username, password and session length
Powered by MySQL Powered by PHP Powered by SMF 1.1.18 | SMF © 2013, Simple Machines Valid XHTML 1.0! Valid CSS!
Search Site | Advertising | Add your link here | Contact Us | Android TV Box
Elektrotekno.com | Free Schematics Search Engine | Electronic Kits | Electronic Accessories
