Home Community
Cold Heat Soldering Tool
May 18, 2013, 07:41:46 PM
Advertisements
No New Posts
Today at 01:39:33 AM
in
Advertisements
by google
|-+  Related to Electronics
| |-+  Electronic Gadgets (Moderators: prateeksikka, gogo2520)
| | |-+  Cold Heat Soldering Tool
« previous next »
Pages: 1 2 [3] Print
Author Topic: Cold Heat Soldering Tool  (Read 15854 times)
Theatronics
Full Member
Gender: Male
www.theatronics.com
View Profile WWW
« Reply #28 on: July 16, 2006, 12:10:48 PM »
The 'COLD HEAT' soldering iron works on the tiny amount of current needed to heat the element at the end of the device.  Look closely at the end of the tip.
It has a divide down the middle.  Both sides of the tip must touch a conductor.
The current flowing through the conductor will cause it to heat very quickly.
On the Top of the device is an LED that should turn RED when the tip is in contact with a good conductor.  AS the heat builds you can then add solder.
On the TV ad they show people (ZAPPING) things together.  In fact that is a BAD thing to do because the solder and metal have not had a chance to 'FLOW' and as a result you will get a cold solder joint.  Leave the device ON the part for a moment and then add the solder. Just like you would with a normal soldering iron.
The tip REALLY DOES cool down as fast as they say. So I do like using mine.
I have a few butane irons I have used also but the heat from the flame on the side of the units melt and burn nearby parts.  The "COLD HEAT' unit has some good uses but it is not a universal tool.
Important tip.  Never heat the SOLDER.  as the solder melts the electrical contact will break and it will be hard to keep the heat flowing. Remember it cools down VERY fast.  Heat the PART then add the solder to the PART not the tip.
Let me know if that helps.
-Mike
Logged
"...Ok, but how do we turn it OFF?"
fullyautomatic12
Newbie
Gender: Male
View Profile
« Reply #29 on: August 21, 2006, 01:15:16 AM »
i have seen those things, i need to get one, i have burned myself with soldering irons way to many times cause it slips, or i fall on it, or just dont pay attention, i got to get one of those
Logged
nanop
« Reply #30 on: August 21, 2006, 02:16:38 PM »
Cold Heat Soldering iron have their goods and bads. I think with some practice, they're on the cutting edge!
For info about cold heat soldering iron, go here:
http://electronics.howstuffworks.com/cold-heat.htm
This site shows how the radioshack cold heat soldering iron works, inside of the iron,  cold heat, and more.  Great Site  Wink
Logged
bobleny
Full Member
Every solution breeds new problems...
View Profile WWW
« Reply #31 on: November 26, 2006, 12:04:24 AM »
I got one of these dumb things for christmas last year and it is not so great for electronics. I got the pro version which appears to be a bit more bulky and hard to handle in tight spaces. I've found the tip for this thing to be a bit big as well, it wants to touch more than I want it to. I have also found that you have to get that tip on there just right or it wont turn on. The only advantage to this thing is that you don't have a cord to get in your way. Other wise, it's not that great.
I would recommend saving your money for a solder desolder station... I would love to have one of those...!
Logged
No good deed goes unpunished.
If at first you don't succeed, destroy all evidence that you ever tried.
Behind every little problem there's a larger problem, waiting for the littler problem to get out of the way.
01010100 01101000 01100001 01110100 00100000 01110111 01100001 01110011 00100000 01100001 00100000 01110111 01100001 01110011 01110100 01100101 00100000 01101111 01100110 00100000 01110100 01101001 01101101 01100101 00101110
Cheer up, the worst has yet to come...
D0T-C0M
Jr. Member
Gender: Male
NB Canada
View Profile
« Reply #32 on: January 27, 2007, 11:52:37 AM »
I have oneand you wouldnt want to use it on sensitive electronic equipment as it circulates a relatively high current through at the point where you are soldering. While it is good for welding small wires together and such I wouldnt recommend it on electronic circuitry.
Logged
jay_maseb
Newbie
View Profile Email
« Reply #33 on: May 19, 2010, 08:10:19 AM »
Where can I get that kind of Soldering stuff?
Logged
Stephenah
Newbie
Gender: Male
View Profile WWW
« Reply #34 on: September 12, 2010, 09:30:13 PM »
Code:
It's a miniature arc welder.  Some Costco's and Sam's Club got them for $12-15.
Replacement heads are $10 so they are "disposable unit".
Grin
Logged
sing more fashion things
« previous next »
Jump to:
Advertisements
No New Posts
in
Advertisements
by google
