Home Community
Basic Transistor Circuits questions
Welcome, Guest. Please login or register.
June 19, 2013, 12:17:46 AM
Home Help Search Calendar Login Register
News: trade your components on this new board: "Components trade"
Advertisements
No New Posts
Today at 01:39:33 AM
in
Advertisements
by google
+  Electronics-Lab.com Community
|-+  Electronics Forums
| |-+  Theory articles (Moderator: redwire)
| | |-+  Basic Transistor Circuits questions
« previous next »
Pages: [1] Print
Author Topic: Basic Transistor Circuits questions  (Read 1426 times)
Siliconwafer
Full Member
Gender: Male
The greatest joy is the joy of Understanding!
spdandavate
View Profile
« on: March 16, 2006, 07:22:27 AM »
While designing a transistorised circuit,say a voltage divider bias,an amplifier etc,should we select the transistor first and then decide the Q-point characterstics based on its datasheet or
we establish the q-point characterstics and then select a suitable transistor?
If condition2 is correct,then what values to select for Ic for say a CE voltage amplifier?deciding that Vce = 1/3 Vcc?leaving 1/3Vcc across Rc and 1/3Vcc across Re?
Logged
Staigen
Electronics God
Gender: Male
God of toobz
195269676 staigeniboja@hotmail.com
View Profile
« Reply #1 on: March 16, 2006, 08:56:57 AM »
Hi there
Usally you design a transistor stage based on its output demands,
voltage, current, power. Then you decide what transistor to use.
The emitter voltage is usally 5-10% of Vcc, but not always.
//Staigen
Logged
Siliconwafer
Full Member
Gender: Male
spdandavate
View Profile
« Reply #2 on: March 17, 2006, 02:07:07 AM »
But How does one decide Q point Ic i.e dc Ic?I find many students assuming Ic of 1 mA,just because its fairly a reasonable value.
So,when to use say,Ic of 1mA when to use Ic of 10mA or 100mA?
Logged
Staigen
Electronics God
Gender: Male
God of toobz
View Profile
« Reply #3 on: March 17, 2006, 02:55:57 AM »
Hi
What is Q? Quiescent? Usally Q means quality in electronics, used in resonant cirquits and filters! The inverse of Q is damping. The quiescent point depends on the output demands, if you need more than 1 mA out, than a quiescent current of 1 mA is a little bit low. Also, if you need an output peak to peak voltage of 10V, than a VCC of 9V is obviously not enough.
//Staigen
Logged
oladiladio
Newbie
View Profile
« Reply #4 on: April 01, 2006, 05:26:54 AM »
A rule of thumb I learned in school:
Ure (voltage across emitter resistor) = 1/10 Uv (power supply voltage)
Uce (voltage across collector-emitter) = 1/2*(Uv - Ure)
Urc (voltage across collector resistor) = 1/2*(Uv - Ure)
Logged
Cabwood
Jr. Member
View Profile
« Reply #5 on: May 31, 2006, 04:18:38 PM »
Perhaps your main concern might be noise. That will determine your choice of transistor right off the bat. Then you look at the noise characteristics of the transistor, and find out the collector current at which the transistor exhibits least noise.
What about the input impedance of the next amplifier stage? Your choice of resistors in an amplifier will be hugely influenced by this.
The source (say a microphone) will greatly influence your choice of base bias resistors. Your choice of emitter resistor will be somewhat limited by the transistor's gain, and bias current.
Perhaps you have to consider battery life. This means your design should draw as little current as possible, usually implying large resistances.
Any amplifier design is a compromise based on these kinds of considerations.
Logged
Pages: [1] Print
« previous next »
Jump to:
Advertisements
No New Posts
in
Advertisements
by google
Login with username, password and session length
Powered by MySQL Powered by PHP Powered by SMF 1.1.18 | SMF © 2013, Simple Machines Valid XHTML 1.0! Valid CSS!
Search Site | Advertising | Add your link here | Contact Us | Android TV Box
Elektrotekno.com | Free Schematics Search Engine | Electronic Kits | Electronic Accessories
