This is a package outline for SOT-23 package
http://www.maxim-ic.com/cgi-bin/packages?pkg=6%2FSOT23&Type=MaxLF = NPN if my German is correct check here!
http://www.fed.de/mailarchive/fed-forum/2002-01/3032.htmlIt is Translated as:
Honoured colleagues,
I look for the type names and the manufacturer of two bipolar
transistors in the SOT-23-Gehaeuse. The construction unit codes read:
"MF" on a PNP transistor "LF" on a NPN transistor
The Pinning is the equivalent BC848/858. Both transistors are from the same manufacturer, since the
construction unit surface and the stempeldruck are perfectly
identical.
Who can help me here? Thank you in advance for each support.
With kind regards
Now here is the Datasheet for the transistor he mentioned.
http://www.semiconductors.philips.com/acrobat/datasheets/BC846_BC847_BC848_5.pdf
