Home Community
amplify the power (infrared)
May 24, 2013, 12:02:13 PM
Advertisements
No New Posts
Today at 01:39:33 AM
in
Advertisements
by google
|-+  Electronics Forums
| | |-+  amplify the power (infrared)
« previous next »
Pages: [1] 2 3 4 Print
Author Topic: amplify the power (infrared)  (Read 4419 times)
ryanleung
Newbie
View Profile
« on: April 03, 2006, 09:50:15 AM »
I would like to use this circuit to transmit the audio signal.
Logged
audioguru
Electronics God
Gender: Male
View Profile
« Reply #1 on: April 03, 2006, 12:08:01 PM »
Hi Ryan,
It looks like a 1MHz oscillator that is amplitude-modulated by the input signal.
A photo-diode or especially a photo-transistor doesn't work at such a high frequency as 1MHz, so I recommend using a lower frequency such as the 38kHz to 40kHz used by remote-controls.
Please attach the schematic of the receiver for us to see how to improve it.
Logged
ryanleung
Newbie
View Profile
« Reply #2 on: April 04, 2006, 12:05:26 AM »
Sorry, this circuit is old version.  I changed the frequency to the 38kHz already.  But the distance between the transmitter and the receiver is very short.  How can i increase the distance?  increase the power? I don't know how to increase it.
Logged
Staigen
Electronics God
Gender: Male
God of toobz
195269676 staigeniboja@hotmail.com
View Profile
« Reply #3 on: April 04, 2006, 12:16:33 AM »
Hi ryanleung
Maybee you should switch to FM instead, and at the same time have it pulsed at a somewhat higher current. A schematic would be fine.
//Staigen
Logged
ryanleung
Newbie
View Profile
« Reply #4 on: April 04, 2006, 05:22:42 AM »
but my project requirement must use AM to transmit the audio signal.   How can i amplify the power and increase the distance???
Logged
audioguru
Electronics God
Gender: Male
View Profile
« Reply #5 on: April 04, 2006, 07:03:41 AM »
What is the DC modulation input levels?
Please attach the schematic of the receiver.
Logged
ryanleung
Newbie
View Profile
« Reply #6 on: April 04, 2006, 07:23:26 AM »
R1 = 470ohm; C1 = 0.1uF; R2 = 1kohm; R3 = 10kohm; IC = LM324
Logged
audioguru
Electronics God
Gender: Male
View Profile
« Reply #7 on: April 04, 2006, 08:07:04 AM »
Hi Ryan,
Your LM324 doesn't have its negative power supply pin 4 connected to a negative supply, no wonder it doesn't work. If pin 4 is connected to ground then the opamp would be an AM detector.
Also, the LM324 has crossover distortion and a very lousy high frequency response, it drops above only 5kHz. I use TL071 single, TL072 dual and TL074 quad low-noise wide-bandwidth opamps for nearly everything because they are inexpensive, have very low distortion, have low noise and operate well to 100kHz. If a TL074 quad opamp is used in your circuit then it would need to have its inputs biased and a diode added in its negative feedback loop.
Logged
ryanleung
Newbie
View Profile
« Reply #8 on: April 04, 2006, 09:07:14 AM »
I connected the pin4 to ground already and the signal was amplified.  The problem occur at receiver or transmitter?  Or the output power of the transmitter insufficient?
Logged
audioguru
Electronics God
Gender: Male
View Profile
« Reply #9 on: April 04, 2006, 11:37:26 AM »
Hi Ryan,
Due to a severe impedance mismatch, your IR receiver has an enormous loss.
R1 is the high value of 470k so that the phototransistor has a high gain. But the value of R2 is so low at only 1k that the output of the phototransistor is nearly shorted.
The opamp should be a type that works well at 38kHz, be in a non-inverting configuration so that its input bias resistor can be as high as 2.2M so the phototransistor's high impedance output is not loaded down. To avoid having a negative supply, the opamp should be biased to half-supply. The opamp can have as much gain as you want and can feed a passive AM detector diode or an active one that uses an opamp.
Your choice of using AM instead of FM for modulation means that your receiver will pickup mains hum from incandescent and fluorescent lights.
Logged
ryanleung
Newbie
View Profile
« Reply #10 on: April 04, 2006, 10:55:13 PM »
1. can I change the value to R1 =100kohm ,R2=2.2kohm,R3=1Mohm and C=0.01uF???
2. can i use the TL072?
3. should I construct the band pass filter to filter the fluorescent light and the noise?
Logged
audioguru
Electronics God
Gender: Male
View Profile
« Reply #11 on: April 04, 2006, 11:15:12 PM »
A 2.2k load on a 100k collector resistor is still a huge attenuator. My suggestion of using a high impedance non-inverting opamp allows the photo-transistor to have its full gain.
I just noticed that R1 was 470 ohms which is much too low. It should be a much higher resistance for good sensitivity and the input impedance of the opamp that it drives should have an impedance at least 5 times higher.
Quote
Yes, it works much better than a low-bandwidth LM324 at 38kHz. But the circuit needs to be changed for it to work.
Quote
You could make a highpass filter to reduce the low frequency mains hum but its harmonics would still pass and sound like a buzz. New compact fluorescent lights have a 38kHz oscillator that would cause severe interference to an AM modulated 38kHz system.
Logged
windoze killa
Full Member
Gender: Male
View Profile
« Reply #12 on: April 05, 2006, 12:50:23 AM »
You could also try using more IR LEDs to increase the amount of radiation.
Logged
ryanleung
Newbie
View Profile
« Reply #13 on: April 05, 2006, 06:29:02 AM »
I used two IR LEDs already.
Logged
« previous next »
Jump to:
Advertisements
No New Posts
in
Advertisements
by google
