Home Community
555 with unconnected trigger
Welcome, Guest. Please login or register.
May 23, 2013, 08:06:24 PM
Home Help Search Calendar Login Register
News: trade your components on this new board: "Components trade"
Advertisements
No New Posts
Today at 01:39:33 AM
in
Advertisements
by google
+  Electronics-Lab.com Community
|-+  Electronics Forums
| |-+  Electronics chit chat (Moderators: redwire, wise old man)
| | |-+  555 with unconnected trigger
« previous next »
Pages: [1] Print
Author Topic: 555 with unconnected trigger  (Read 750 times)
autir
Full Member
I love the smell of solder in the morning ]-D
View Profile
« on: March 02, 2006, 07:31:13 AM »
Hello all.
I have built a simple circuit with a 555 as a monostable multivibrator on my breadboard. The circuit is the one documented in TI's 555 datasheet. The output goes to a 0-999 counter (three 7447s and three 7490s ICs). The 0-999 counter is a seperate circuit built on stripboard and works fine. I have a problem with the 555, though. When the "trigger" pin is unconnected and close to my hand the circuit starts to oscillate or counts double (produces twin pulses?). What happens?
The final circuit I want to build is one where the counter will advance by one every time two metal wires touch each other. But leaving the trigger wire unconnected causes all sort of problems. I connected a 4069 IC to the trigger wire, so as to ensure that triggering will take place only with voltage and not by accidental grounding. But the problems persisted.
I am thinking to build a 555 astable circuit with the junction of the metal wires as its power line. Or perhaps a transistor working as a switch...
Any thoughts?
Logged
allvol
Jr. Member
Gender: Male
View Profile Email
« Reply #1 on: April 14, 2006, 12:38:54 AM »
It has been several days since you posted your question, and you may have already solved your problem.
The simplest fix is using an NPN transistor, such as the 2N2222 in an emitter follower configuration.
Logged
Hovering somewhere on the learning curve.
Pages: [1] Print
« previous next »
Jump to:
Advertisements
No New Posts
in
Advertisements
by google
Login with username, password and session length
Powered by MySQL Powered by PHP Powered by SMF 1.1.18 | SMF © 2013, Simple Machines Valid XHTML 1.0! Valid CSS!
Search Site | Advertising | Add your link here | Contact Us | Android TV Box
Elektrotekno.com | Free Schematics Search Engine | Electronic Kits | Electronic Accessories
