Home Community
Auto/deep cell charger
Welcome, Guest. Please login or register.
May 20, 2013, 08:59:08 AM
Home Help Search Calendar Login Register
News: trade your components on this new board: "Components trade"
Advertisements
No New Posts
Today at 01:39:33 AM
in
Advertisements
by google
+  Electronics-Lab.com Community
|-+  Electronics Forums
| |-+  Electronics chit chat (Moderators: redwire, wise old man)
| | |-+  Auto/deep cell charger
« previous next »
Pages: [1] 2 Print
Author Topic: Auto/deep cell charger  (Read 1981 times)
oldgrandpainmi
Jr. Member
Gender: Male
View Profile WWW
« on: June 04, 2006, 07:41:30 AM »
Hello all.
I understand the difference between a standard lead/acid automotive battery versis a deep cell lead/acid battery.  What I would like to know is the actual difference between the corresponding chargers.
I run deep cells while fishing, and am aware that using a standard charger will not work correctly and you shouldn't charge a deep cell on an automobile (jumper cables).
Is there a circuit available for a typical 2/15/100 automatic charger? (2a slow charge, 15a fast charge, 100a start)  Building one is out of the question, as it is much cheaper to buy than build, so the circuit would be for my reference.
I also would like to know if there are any problems trying to charge 3 or 4 deep cells on a charger at once?  (parrellel hook-up)
Lasty, is there a way to rejuvinate lead/acid battery's, much like rejuvinating NiCad's?? (NiCad Zapper)
Any ideas?
oldgrandpainmi
Logged
Who say's you can't teach an old dog, new tricks???
Kasamiko
Guest
« Reply #1 on: June 04, 2006, 10:43:08 PM »
Maybe something like this?
Logged
indulis
Electronics God
View Profile
« Reply #2 on: June 05, 2006, 06:23:32 AM »
Check out the battery section on this website.....
http://www.golfcarcatalog.com/phpbb2/
When a lead-acid battery is "gone", it is GONE!! No amount of "zapping" is going to bring it back to life... you can't change the laws of physics!!
Logged
oldgrandpainmi
Jr. Member
Gender: Male
View Profile WWW
« Reply #3 on: June 05, 2006, 07:09:08 AM »
Kasamiko,
Thanks for the artical.  It is the same basic idea I have used for NiCad's for years.  (Charge a cap and discharge it to the battery).  But you have to remind me about the capacitors.  They are listed (for example) 100mf and 10nf.  I know this is not what they actually are, as a 100 millifarad cap won't fit on this PCB and a 10 nanofarad cap is unreal, so I ask, is it actually 100uF and 10 pF?  It is stated elseware in a different thread, but I am running out the door for work.  I am also curious to see if the wire wound inductors can be hand wound?  Have any idea?
I would rather try this than to spend $50-100 every other year for batterys for my boat.  If I could discharge an auto battery like I deep cell, I'd save a lot of $$ every year!!!!
indulis:
This is not necessarily true!!!  I have had auto and deep-cell batterys (I have one now) that will charge to 90% and discharge after 1/2 hour thru a typical load.  I think a "Zapper" will work to rejuvinate this one.  I have thrown out batterys that start with 0vdc and after 3 hours, can't reach 50% voltage.  I believe this is the type of problem you speak of.  I see SO MANY battery's for sale for $5 that it MAY be worth building this circuit just to see if 50% of them can be rejuvenated.  It then would be worth it.
I see the same thing said about NiCad's.  "If they can't hold a charge, then replace them!"  This is wrong!!!  A NiCad "Zapper" can and will zap 50%-75% back to life.(95%+ of origonal capacity)  You have to zap individual cells in a multi-cell pack, but it is cheaper than paying $165 for this laptop battery or %$250 for the laptop I just pitched!!!!  I know this for fact, as I used to do it for friend and relatives.  The biggest problem is that 25%-50% of the zapped batterys will get destroyed internally, but when you can save a few dozen, it makes it worth it!!!
oldgrandpainmi
Logged
oldgrandpainmi
Jr. Member
Gender: Male
View Profile WWW
« Reply #4 on: June 05, 2006, 07:15:10 PM »
Kasamiko,
I just got home from work and looked for your reply, then it hit me!!!
For the example I used, a 100mF cap = .1uF ,
Logged
indulis
Electronics God
View Profile
« Reply #5 on: June 05, 2006, 09:55:16 PM »
A 220uH inductor is the same as a .22mH
m is 10^-3 and u is 10^-6 and n is 10^-9 and p is 10^-12
Once the chemistry of a lead acid battery is depleted, NO AMOUNT OF ZAPPING WILL BRING IT BACK TO LIFE, PERIOD!!! This is a irrefutable fact... the zapper company just wants to sell you some gadget. The same laws of physics/chemistry that apply to you and me, applies to them. If you can't get back to the batteries original ampacity, nothing has been rejuvinated. Hell, I can take a lead acid battery that has a shorted cell, over charge it and it will work just fine in a car as long as I start and charge it every morning and evening. If this is what you consider "rejuvinated" then yes you are right and it will work. For my money, if you can't get back to the original spec's window, than no rejuvination has taken place.
Logged
Ante
Electronics God
Gender: Male
Never stop learning!
View Profile
« Reply #6 on: June 06, 2006, 05:23:13 AM »
Hi oldgrandpainmi,
I have been into testing different methods of reviving lead acids through the last two decades. One of my circuits is posted here: http://www.electronics-lab.com/projects/power/036/index.html
Logged
indulis
Electronics God
View Profile
« Reply #7 on: June 06, 2006, 05:53:14 AM »
Quote
...The object is to get the cell voltage high enough for the sulphate to dissolve...
Ante
Do you by chance have the "chemistry" to support that statment.... I'd love to see it!!
Indulis
Logged
Ante
Electronics God
Gender: Male
View Profile
« Reply #8 on: June 06, 2006, 06:34:09 AM »
Hi Indulis,
I am not a chemist; I don’t have any chemical formulas to give. The important thing to mention here is; the battery must be mechanically in good condition for this to work. If the plates inside are damaged or out of alignment causing short circuit there is no chance what so ever to revive the battery.
What I can tell you is; the sulphate crystals become harder the longer they are allowed to be left alone thus harder to dissolve which makes it impossible for a standard charger to cure. If you apply a higher voltage than the standard charger normally does the battery will boil and overheat and destroyed completely. If a battery is well charger at all times the forming of crystals are kept to a minimum. I have tried this method/circuit against many types of chargers and it does its job where other “special” chargers fail.
Logged
oldgrandpainmi
Jr. Member
Gender: Male
View Profile WWW
« Reply #9 on: June 06, 2006, 06:58:30 AM »
Ante,
I downloaded your circuit and will look at it further this evening.
I did notice that the primary voltage is 230vac at 50hz.
Logged
Ante
Electronics God
Gender: Male
View Profile
« Reply #10 on: June 06, 2006, 09:39:42 AM »
Hi Bruce,
The only thing that comes to mind is the snubber circuit around the triac. You will find suitable values for 60Hz in the data sheet of the triac you chose to use for the circuit. The nF is nano Farad which equals 1000pF or 1 thousand of a mF (uF).
Logged
oldgrandpainmi
Jr. Member
Gender: Male
View Profile WWW
« Reply #11 on: June 07, 2006, 07:03:15 AM »
I got a reply from the author.
Yep, a nonofarad (n) = a nanofarad, but a Microfarad (m in Europe) = uF U.S.!  I figured that if they used a different symbol for Micro, then they would have used a different for Nano, which isn't the case.  Thus the confusion.
Also, L1 is a .22mH (220uH) not a 220mH as stated throughout the artical.  I found a neat link on how to build these inductors here:
http://colomar.com/Shavano/inductor_info.html
oldgrandpainmi
Logged
MP
Electronics God
30+ Years Engineer
View Profile
« Reply #12 on: June 11, 2006, 12:03:20 AM »
Logged
oldgrandpainmi
Jr. Member
Gender: Male
View Profile WWW
« Reply #13 on: June 11, 2006, 09:12:55 AM »
MP,
Makes more sence that what I've been running into.
1000pF=1nF
1000uF=1mF
Etc.
Just have to remember to convert and re-convert before I look for parts in my suppliers manuals,
Logged
Pages: [1] 2 Print
« previous next »
Jump to:
Advertisements
No New Posts
in
Advertisements
by google
Login with username, password and session length
Powered by MySQL Powered by PHP Powered by SMF 1.1.18 | SMF © 2013, Simple Machines Valid XHTML 1.0! Valid CSS!
Search Site | Advertising | Add your link here | Contact Us | Android TV Box
Elektrotekno.com | Free Schematics Search Engine | Electronic Kits | Electronic Accessories
