Home Community
12 V DC to a 220V AC Inverter AMplfier Design
Welcome, Guest. Please login or register.
May 20, 2013, 07:04:34 AM
Home Help Search Calendar Login Register
News: trade your components on this new board: "Components trade"
Advertisements
No New Posts
Today at 01:39:33 AM
in
Advertisements
by google
+  Electronics-Lab.com Community
|-+  Electronics Forums
| |-+  Electronic Projects Design/Ideas (Moderators: Dazza, gogo2520, Herman the German)
| | |-+  12 V DC to a 220V AC Inverter AMplfier Design
« previous next »
Pages: [1] 2 3 ... 15 Print
Author Topic: 12 V DC to a 220V AC Inverter AMplfier Design  (Read 17376 times)
faizanbrohi
Full Member
Gender: Male
ADRENALINE - to THe XtreMe
faizanbrohi@hotmail.com
View Profile
« on: June 14, 2006, 12:43:15 PM »
THere is an idea in my mind which i want to ask if it is applicable or not. THe Idea is to create a SInewave Oscillator , amplify the sine wave signal and that it reaches a 220V P-P ,
Sine wave oscillator -->  Class A Amplfier --> 220V Sine wave AC Signal
The only thing i don't know is how the amp need to be designed or even if this idea is correct
Logged
audioguru
Electronics God
Gender: Male
I'm a theory expert! $crooge and I are thrifty.
View Profile
« Reply #1 on: June 14, 2006, 02:23:41 PM »
A 220VAC sinewave is 622Vp-p.
A Class-A amplifier uses its full power whether it is fully loaded or not, so becomes extremely hot and wastes as much power as it delivers at full load. It is a total waste of power at low loads.
Think about using a Class-D switching amplifier that is very efficient (doesn't waste much power because it doesn't get very hot).
The inverter has a very high output voltage so maybe it would be less expensive to use a high current medium voltage Class-D audio amplifier driving a stepup transformer.
Logged
faizanbrohi
Full Member
Gender: Male
View Profile
« Reply #2 on: June 15, 2006, 09:25:20 AM »
i have another idea  why use a power amplifier   Grin
Generate a Sine wave oscillator and then use a transformer simply to step up the Signal of 10V to 220V , i mean as simple as it gets . Beacuse since the 10V is an AC SIgnal. But as simple as it is , the Current Rating of the oscillator should be very high . so we can make a sinewave oscillator using power transistors with high current ratings , or power op amps .
plz reply if it is correct  Huh
Logged
audioguru
Electronics God
Gender: Male
View Profile
« Reply #3 on: June 15, 2006, 09:58:05 AM »
Your idea of using a linear sine-wave generator wastes a lot of power as heat. Even if the high current output of the generator operated in Class-B to save power when the load was low, it would heat about the same power as the load at full output. Half the power from the battery would be wasted.
If you use a 12V battery then the output from the generator would be a sine-wave of only about 3.5V RMS. If it was designed like an audio power amplifier then for 1000W output the circuit would heat with 1000W, the battery current would be 184A and the load on the circuit will have an impedance of only 0.012 ohms.
If you use a Class-D switching output then only 5% to 20% of the battery's power would be wasted as heat.
Logged
Muhammad Abu Bakar
Full Member
Gender: Male
My dear Aziz Shaheed
muhammadabubakar239
View Profile Email
« Reply #4 on: June 15, 2006, 10:11:12 AM »
Then what about class-C amplifier?
Why it isn't used at power frequencies. After all it has good efficiency!
Logged
Muhammad Abu Bakar
audioguru
Electronics God
Gender: Male
View Profile
« Reply #5 on: June 15, 2006, 02:27:15 PM »
A Class-C amplifying transistor conducts only part of the time so has very high distortion. Radio circuits use them because they can tune the LC load to substatially reduce the distortion. 50Hz or 60Hz is such a low frequency that an inductor and capacitor to tune to the low frequency with high power is impractical.
Logged
Muhammad Abu Bakar
Full Member
Gender: Male
muhammadabubakar239
View Profile Email
« Reply #6 on: June 16, 2006, 09:54:34 AM »
Soes impractical means immpossible?
One more question.
In an LC tank often a transfo is used as inductor(antenna on other side). Does this transfo has some rigid inductance or it depends upon the load impedence?
Logged
Muhammad Abu Bakar
audioguru
Electronics God
Gender: Male
View Profile
« Reply #7 on: June 16, 2006, 10:32:59 AM »
Look in Google for "ferro-resonant transformer". It has a third winding that is tuned by a capacitor to be a tank circuit. It is designed so that its core saturates which makes voltage regulation but a square-wave, then the tuned winding converts the square-wave to a sine-wave.
Logged
faizanbrohi
Full Member
Gender: Male
View Profile
« Reply #8 on: June 18, 2006, 12:36:42 AM »
I think you don't get the point i am saying if use a ordinary sine wave oscillator and then attach it to a Step up trasformer , that is it
Logged
faizanbrohi
Full Member
Gender: Male
View Profile
« Reply #9 on: June 18, 2006, 12:42:30 AM »
ok i get it , it heats more at the oscillator stage , but it can be a way to tackle it good ....
Logged
audioguru
Electronics God
Gender: Male
View Profile
« Reply #10 on: June 18, 2006, 06:18:41 AM »
It is not good to make an inverter that wastes as much power as the load uses.
An inverter should be efficient, and use a switching amplifier instead of a linear amplifier.
Logged
faizanbrohi
Full Member
Gender: Male
View Profile
« Reply #11 on: June 18, 2006, 08:31:02 AM »
So are there any ideas for a switching amplifer and how is it to be interfaced with my oscillator idea... and the transformer one..
Logged
audioguru
Electronics God
Gender: Male
View Profile
« Reply #12 on: June 18, 2006, 08:47:34 AM »
Class-D switching amplifiers are complicated. Ones for audio use a fairly low supply voltage. TI has an IC with up to only 240W output.
A sine-wave oscillator would drive a class-D amplifier which would drive a stepup transformer.
Logged
faizanbrohi
Full Member
Gender: Male
View Profile
« Reply #13 on: June 18, 2006, 03:00:29 PM »
A switching Class D AMplfier is hard to make , is it no other idea to use any other type of amplfier.
Logged
« previous next »
Jump to:
Advertisements
No New Posts
in
Advertisements
by google
Login with username, password and session length
Powered by MySQL Powered by PHP Powered by SMF 1.1.18 | SMF © 2013, Simple Machines Valid XHTML 1.0! Valid CSS!
Search Site | Advertising | Add your link here | Contact Us | Android TV Box
Elektrotekno.com | Free Schematics Search Engine | Electronic Kits | Electronic Accessories
