Home Community
0-30 Vdc Stabilized Power Supply
Welcome, Guest. Please login or register.
May 22, 2013, 05:27:44 AM
Home Help Search Calendar Login Register
News: trade your components on this new board: "Components trade"
Advertisements
No New Posts
Today at 01:39:33 AM
in
Advertisements
by google
+  Electronics-Lab.com Community
|-+  Electronics Forums
| |-+  Projects Q/A (Moderators: gogo2520, Herman the German, Hero999)
| | |-+  0-30 Vdc Stabilized Power Supply
« previous next »
Pages: 1 ... 120 121 [122] 123 124 ... 126 Print
Author Topic: 0-30 Vdc Stabilized Power Supply  (Read 216476 times)
Alf_Melmok
Newbie
View Profile Email
« Reply #1694 on: May 12, 2012, 05:25:41 PM »
You are right, i forgot about  the voltage losses.
In my country mains voltage change from 200 to 240 very often (In rare cases, even is worse (phase is not uniformly loaded)). That's why i want to limit the input voltage.
It's a vicious circle. In my country i can't buy op amp that you recommend. So that i can't use 28VAC transformer. And i can't find 28-30VAC transformer. I can't find another scheme similar PSU. I just want this power supply with 20V transformer.  Cry
Thanks for your help
Logged
audioguru
Electronics God
Gender: Male
I'm a theory expert! $crooge and I are thrifty.
View Profile
« Reply #1695 on: May 12, 2012, 06:35:45 PM »
Here in Canada my inexpensive mains electricity is 120V. Sometimes it surges very high to 121V and sometimes it drops very low to 119V. It fails maybe every 2 or 3 years for a moment during a thunderstorm.
There are many electronic parts distributors here that have ANYTHING and EVERYTHING at a good price.
If I order a part by phone or online before 8:00PM then it is delivered to me the next morning.
Maybe in your country you should do gardening instead of electronics.
Logged
Alf_Melmok
Newbie
View Profile Email
« Reply #1696 on: May 12, 2012, 08:11:34 PM »
I envy you. But it's not funny. By our standards in the electrical network there shall be 220V +20 % -20 %. You can calculate how much it turns out (176-264 It's normal Shocked). All of our electronics designed for this.
Logged
asdewq
Newbie
View Profile Email
« Reply #1697 on: May 26, 2012, 02:29:41 PM »
hey guys i need some help
i've built this psu project from the first schematic (the original) with the tl081 and everything and it didn't burn up immediately after being switched on as suggested by some
i tried testing the circuit and the current limitation/regulation works fine but voltage regulation does not and im wondering if anyone has had the same problem or if someone has a suggestion as to how to fix this problem
this is a great project and i need this psu for some other projects  and i've spent quite a lot of money on parts (electronics parts are still a bit expensive where i live) and i would hate it this build was a waste of time and money
please help and thank you in advance
Logged
asdewq
Newbie
View Profile Email
« Reply #1698 on: May 26, 2012, 05:23:18 PM »
after about two more hours of tinkering with the psu i finally got some kind of reaction on the output of the psu but now i can only get either 0V or 31V nothing in between
any suggestions?
Logged
audioguru
Electronics God
Gender: Male
View Profile
« Reply #1699 on: May 26, 2012, 07:22:11 PM »
The input to the output amplifier is 0V to +11.2V from the voltage adjust pot.
The output amplifier is simply opamp U2 with the driver transistor and output transistor as emitter-followers boosting the output current. The output amplifier has R11 (27k) and R12 (56k) for over-all negative feedback which sets the gain too high at (56k/27k) + 1= 3.074. Then the output should be able to go from 0V to (11.2V x 3.074=) 34.4V if the unregulated DC voltage is high enough.
Maybe you have the pins on the driver transistor or output transistor mixed up so that they are on-off switches instead of emitter-followers.
Logged
asdewq
Newbie
View Profile Email
« Reply #1700 on: June 02, 2012, 07:12:39 AM »
Solved it. I accidentaly put the wrong transistor in the wrong place.
Just one more thing. I tested one circuit (I built two) by shorting the output to see the max current rating and it put out almost 5 amps. Those 5 amps burned through the rectifier diodes but everything else was fine. Did you get 5 amps as max current on the output?
Logged
audioguru
Electronics God
Gender: Male
View Profile
« Reply #1701 on: June 02, 2012, 11:08:37 AM »
Yes, the original project was missing calibration trimpots to reduce the maximum output voltage to 30.0V and the maximum output current to 3.0A.
The modified circuit has the calibration trimpots added and uses a high current rectifier bridge module that can be bolted to a heatsink.
Logged
asdewq
Newbie
View Profile Email
« Reply #1702 on: June 02, 2012, 01:25:00 PM »
Would you mind posting a link to the modified circuit?
Logged
audioguru
Electronics God
Gender: Male
View Profile
« Reply #1703 on: June 03, 2012, 07:45:23 PM »
I have looked it up on my hard drive and posted it on one of the many threads about the modified circuit hundreds of times.
Here they are again:
Logged
asdewq
Newbie
View Profile Email
« Reply #1704 on: June 04, 2012, 02:43:42 PM »
Thx man. Sorry to bother you
Logged
audioguru
Electronics God
Gender: Male
View Profile
« Reply #1705 on: June 04, 2012, 08:49:56 PM »
You are not bothering me.
I wish that there is a place on this site to post the important modifications and I hope you understand that the original project will not make regulated 30VDC at 3A (it fails to meet its spec's) and that many of its parts were overloaded (then it has poor reliability).
Logged
asdewq
Newbie
View Profile Email
« Reply #1706 on: June 05, 2012, 04:19:39 PM »
Yes, sadly Smiley
I found out the hard way that the PSU generates around 26 - 27V at 3.5 amps
In the near future I'll make the upgraded version and i will, hopefully, design a pcb (if one is not available) and post it here.
Logged
red baron
Newbie
View Profile Email
« Reply #1707 on: June 26, 2012, 05:42:35 AM »
Hi Audioguru
Seems like you have been on this project for some time, and getting a bit frustrated that you have to repeat the same information endlessly - I understand, but I am now new to this project and looking forward to constructing the psu according to the latest version.
I have your bill of materials and latest circuit diagram, what is the status with an appropriate pcb?  Does someone have the masks or can I use the originals and simply change components?
Logged
« previous next »
Jump to:
Advertisements
No New Posts
in
Advertisements
by google
Login with username, password and session length
Powered by MySQL Powered by PHP Powered by SMF 1.1.18 | SMF © 2013, Simple Machines Valid XHTML 1.0! Valid CSS!
Search Site | Advertising | Add your link here | Contact Us | Android TV Box
Elektrotekno.com | Free Schematics Search Engine | Electronic Kits | Electronic Accessories
