Home Community
0-30 Vdc Stabilized Power Supply
Welcome, Guest. Please login or register.
May 23, 2013, 06:28:01 PM
Home Help Search Calendar Login Register
News: trade your components on this new board: "Components trade"
Advertisements
No New Posts
Today at 01:39:33 AM
in
Advertisements
by google
+  Electronics-Lab.com Community
|-+  Electronics Forums
| |-+  Projects Q/A (Moderators: gogo2520, Herman the German, Hero999)
| | |-+  0-30 Vdc Stabilized Power Supply
« previous next »
Pages: 1 ... 121 122 [123] 124 125 126 Print
Author Topic: 0-30 Vdc Stabilized Power Supply  (Read 216575 times)
audioguru
Electronics God
Gender: Male
I'm a theory expert! $crooge and I are thrifty.
View Profile
« Reply #1708 on: June 26, 2012, 08:21:25 AM »
A few people designed pcbs for this project but I did not save them.
Logged
KevinIV
Electronics God
Gender: Male
View Profile
« Reply #1709 on: June 26, 2012, 08:13:19 PM »
The PCB consruction for both high frequency and low frequency circuits is more complicated than that of the average use for this power supply. I would say to use a simple solder and wire circuit. Most often the problems will be the rest of the circuit. If you can fabricate a PCB, use larger conductors that will handle the current.
Logged
tdx
Newbie
Gender: Male
View Profile Email
« Reply #1710 on: June 29, 2012, 11:40:27 AM »
I have built this power supply some time ago and used the PCB in the PDF attached for it. From the PCB's posted it is by far the best I found with proper trace sizes and probably the best layout you can do for a single sided board with this circuit. The PDF includes a redrawn schematic and parts list but the part names DO NOT MATCH the ones posted by audioguru and others, so pay close attention when assembling.
The attached PDF is not mine, I forget the username of the person who created it but all credit goes to them.
Logged
audioguru
Electronics God
Gender: Male
View Profile
« Reply #1711 on: June 29, 2012, 12:53:41 PM »
The 6th page shows the username Picmaster who did it.
Logged
Qwicol
Newbie
View Profile Email
« Reply #1712 on: August 14, 2012, 12:55:23 PM »
Hi, it's my first post here Smiley
 I've just finished soldering of this http://www.electronics-lab.com/projects/power/001/index.html  power supply and I've encountered following issue:
In max position of potentiometer responsible for maximum current and in short circuit with amp meter my max output current is only about 40mA and current limiter is working.
What should I check in the first place?
I've checked op amps and voltage regulation and they're ok.
I'm counting on Your help.
And sorry for possible gramatic errors, i'm rather bad at writing in english [I'm from Poland] Wink
Logged
audioguru
Electronics God
Gender: Male
View Profile
« Reply #1713 on: August 15, 2012, 08:47:09 AM »
The original project has many errors and does not work properly and is not reliable. That is why this thread and another thread recommends modifications.
R7 senses the output current. It is 0.47 ohms and with 3A it produces 1.41V across it which is fed to the inverting input pin 2 of opamp U3. The positive non-inverting input pin 3 of U3 has the voltage from the current-setting pot P2. U3 in the original circuit needs the negative supply of -5.6V on its pin 4. when the sensed voltage exceeds the set voltage then the output of U3 goes low enough for D9 to reduce the output voltage until the output current is reduced to the set current.
U2 drives the driver transistor Q2. Q2 drives the high current output transistor Q4. There should be much more than 3A of output current when the output is shorted.
Logged
fly3rman
Newbie
View Profile Email
« Reply #1714 on: August 16, 2012, 09:10:15 AM »
Hey guys,
as my power supply is finished and actually working, i was testing very heavy loads (2x12volt halogen lamps) with it.
But something is gone wrong, my voltage regulation doesnt work anymore and i get fully 40 volts on my output. Also U2 is getting very hot, so i replaced it, still same problem.
The current limiting is still working, i can turn current to zero and led is also showing that.
Any idea where to start and which parts to check?
Logged
audioguru
Electronics God
Gender: Male
View Profile
« Reply #1715 on: August 16, 2012, 05:43:54 PM »
U2 gets very hot if the pins on the driver transistor are connected backwards because then the transistor operates like a simple series diode.
Maybe you built the defective original version that used the old 2N2219 driver transistor that fails when it gets too hot and it is difficult to keep cool.
Maybe the output transistors had a heatsink too small so they melted and are now shorted.
Logged
fly3rman
Newbie
View Profile Email
« Reply #1716 on: August 30, 2012, 01:42:44 PM »
You were right, it was a output transistor  has died (2n3055). But they are on a huge cooler. I replaced them now, hooked up my multimeter for amper-measurement and ... one died again.
So it seems only one of them route the power, and dies. They were from the same charge, so resistance and hfe shouldnt be that different. Ideas why they dont share the power not symmetrical.
Logged
audioguru
Electronics God
Gender: Male
View Profile
« Reply #1717 on: August 30, 2012, 08:37:33 PM »
Transistors with the same part number are not the same. Their hFE and base-emitter voltage are different so one transistor hogs the current and gets hotter which makes it hog more current and get hotter which... (Thermal Runaway).
The emitter resistor added in series with each output transistor's emitter makes them properly share the current.
Calculate how much heating a low output voltage and a high output current makes and you will see that a huge heatsink is needed maybe with a fan.
Logged
KevinIV
Electronics God
Gender: Male
View Profile
« Reply #1718 on: August 31, 2012, 07:52:32 PM »
There is nothing wrong this stabilized 30Vdc power supply. Having not tested the orginal circuit, it must be a good design, or it would not be posted. Since it's a good design, but doesn't meet your requirements, a totally new design is needed. The engineering principle behind this design is found in many different power supplies. Can't you just buy this power supply from the website?
Logged
audioguru
Electronics God
Gender: Male
View Profile
« Reply #1719 on: September 01, 2012, 07:11:46 AM »
Kevin,
This power supply project is defective which is why I fixed it:
1) It is not reliable since many parts (the transformer, the rectifiers, the transistors and many resistors) are overloaded and burn out.
2) The opamps operate with a total supply voltage that is more than their maximum allowed supply voltage.
3) It does not provide 30V at 3A because the transformer voltage is too low.
This project is a kit sold by a company in Greece. I don't know what they do about people complaining about its problems.
Many defective projects have been posted here. I fixed a few of them.
Logged
rosana
Newbie
View Profile Email
« Reply #1720 on: September 05, 2012, 04:02:15 PM »
i donīt know how i have to put the "legs" of the trimpot in wich number the mc4071 (U2)...
Logged
audioguru
Electronics God
Gender: Male
View Profile
« Reply #1721 on: September 05, 2012, 06:38:51 PM »
U2 is an MC34071. Its RV1 input offset voltage trimpot is 10k and is wired as shown on the schematic. Its voltage calibration trimpot RV2 is 20k and is wired as shown on the schematic.
The middle leg on a trimpot is its slider which is the middle pin with the arrow of the trimpot on the schematic.
Logged
« previous next »
Jump to:
Advertisements
No New Posts
in
Advertisements
by google
Login with username, password and session length
Powered by MySQL Powered by PHP Powered by SMF 1.1.18 | SMF © 2013, Simple Machines Valid XHTML 1.0! Valid CSS!
Search Site | Advertising | Add your link here | Contact Us | Android TV Box
Elektrotekno.com | Free Schematics Search Engine | Electronic Kits | Electronic Accessories
