Home Community
Inverter Generator
Welcome, Guest. Please login or register.
May 22, 2013, 04:11:40 AM
Home Help Search Calendar Login Register
News: trade your components on this new board: "Components trade"
Advertisements
No New Posts
Today at 01:39:33 AM
in
Advertisements
by google
+  Electronics-Lab.com Community
|-+  Electronics Forums
| |-+  Electronic Projects Design/Ideas (Moderators: Dazza, gogo2520, Herman the German)
| | |-+  Inverter Generator
« previous next »
Pages: [1] Print
Author Topic: Inverter Generator  (Read 1160 times)
acdc
Newbie
View Profile
« on: July 09, 2006, 04:56:51 AM »
I bought a ups (Emerson AP203) from a junk yard its 2.5KV Online UPS it’s a nice peace of work. UPS works fine except the batteries are dead 12V 6ah 30 pcs Batteries in series connection that supply a DC of more than 370V its labeled caution 410V DC.
I gave it a test run by plugging it  and for batteries I convert 220AC to DC with a full wave rectifier and 2200uf 4000V DC capacitor UPS started but it shows battery low coz its not getting its full supply . Replacing batteries pretty expensive what is my plan is  for the DC 410V get a 950W Generator and rewind it to  get an out put of 410DC and supply it to the UPS so when black outs I can use the UPS as a power source like and Inverter Generator will it work? What are the modifications I need?
Please let me know your ideas
ACDC
Logged
acdc
Newbie
View Profile
« Reply #1 on: July 10, 2006, 10:37:18 AM »
Is there any one could help me out please
ACDC
Logged
Ante
Electronics God
Gender: Male
Never stop learning!
View Profile
« Reply #2 on: July 10, 2006, 01:25:32 PM »
I believe there are too many unknowns in your equation to give a short or precise answer. What you have told us so far brings up a few questions like: What’s the UPS requirement for the input voltage, stability, current, noise and so on? The generator, data, how to run it, how to regulate its output so that nothing’s going to fry?
And this is just to begin with! Cool
Logged
acdc
Newbie
View Profile
« Reply #3 on: July 11, 2006, 10:11:00 PM »
here u go
220Vinput   220V out put   13.5V sealed lead acid bataries 30 pcs in series conection that produce around 410VDC
bataries are dead now im trying to run it witout bataries with the help of a generator
during black outs
ACDC
Logged
Ante
Electronics God
Gender: Male
View Profile
« Reply #4 on: July 13, 2006, 05:35:18 AM »
Hi acdc,
Sorry, not much to go on. The output from the generator might have noise which won’t be accepted by the input electronics. The surge at startup might stir up some EMF which could be lethal the electronics! As I said “too many unknowns in your equation to give a short or precise answer”!
Logged
MP
Electronics God
30+ Years Engineer
View Profile
« Reply #5 on: July 13, 2006, 09:24:36 AM »
acdc,
Is there a chance that this unit has a schematic attached inside that you could scan and post? It would be much more helpful to see how it is already setup.
As ante has mentioned, there are too many parameters to be able to give a "one size fits all" type of answer.
MP
Logged
Gazza
Jr. Member
Gender: Male
aaron_gascoyne@hotmail.com
View Profile
« Reply #6 on: October 29, 2006, 12:04:50 AM »
acdc,
MP
I know this is an older post, but I have a lot of UPS experience.
It sounds like you found an old Emerson UPS with bad batteries. Most likely there is only a few bad batteries in the string so you wont need to replace all of the batteries.
What you need to do is get a constant current supply and inject each battery block with 10A of current. With a DMM measure the voltage across each cell. You should get a voltage in the 80-150 mv range. If the drop is above 1V there is an open cell and you need to replace that block.
Since all of the batteries are in series they all need to be functional for the string to operate.
As far as the generator is concerned, are you trying to use a DC generator to power the DC bridge? Or using a transfer switch have a standby AC generator.
I guess it doesn't matter because neither will work.
DC Generator: If you use a DC generator to feed the DC Link during a power failure, what is going to turn the generator? The Power is off, that's why you bought a UPS.  I can think of at least 3 more major problems this would cause.
AC Generator: This wont work without batteries either. The function of the batteries is to bridge the gap between the beginning of the power failure and the time it takes the generator to ramp up to full voltage.
If you want your UPS to work, you are going to have to invest in the new batteries.
Logged
Pages: [1] Print
« previous next »
Jump to:
Advertisements
No New Posts
in
Advertisements
by google
Login with username, password and session length
Powered by MySQL Powered by PHP Powered by SMF 1.1.18 | SMF © 2013, Simple Machines Valid XHTML 1.0! Valid CSS!
Search Site | Advertising | Add your link here | Contact Us | Android TV Box
Elektrotekno.com | Free Schematics Search Engine | Electronic Kits | Electronic Accessories
