Home Community
Automated plant watering
Welcome, Guest. Please login or register.
May 19, 2013, 08:54:35 AM
Home Help Search Calendar Login Register
News: trade your components on this new board: "Components trade"
Advertisements
No New Posts
Today at 01:39:33 AM
in
Advertisements
by google
+  Electronics-Lab.com Community
|-+  Electronics Forums
| |-+  Electronic Projects Design/Ideas (Moderators: Dazza, gogo2520, Herman the German)
| | |-+  Automated plant watering
« previous next »
Pages: [1] Print
Author Topic: Automated plant watering  (Read 658 times)
alexbox
Newbie
View Profile
« on: October 29, 2006, 07:38:56 AM »
I would like to build a circuit to automatically measure the dryness of the soil in a hanging basket and then water it when required. Some type of soil probe and a water solenoid set up.
Any ideas?
Logged
Gazza
Jr. Member
Gender: Male
aaron_gascoyne@hotmail.com
View Profile
« Reply #1 on: October 29, 2006, 08:34:01 AM »
Any ideas?
If I was doing this, I would use a Microcontroller. I have no experience in soil sampling, so I don't know what the proper device is, I did find this. http://www.berryhilldrip.com/Irrometr.htm#Model%20'R
You could set up the controller to monitor the output level of the sensor and set up some limits, at a low level for moisture, trigger a solenoid to a water reservoir, at the high level of moisture turn off the solenoid.
Logged
audioguru
Electronics God
Gender: Male
I'm a theory expert! $crooge and I are thrifty.
View Profile
« Reply #2 on: October 29, 2006, 09:33:49 AM »
I am using many of the Plants Watering Watcher-2 devices and discovered that different types of soil and water have a different resistance. Distilled water (rain?) is an insulator while my tap water conducts the same as salt water. Perilite is also an insulator but soil with some fertilizer salts conducts well.
If soil has been dry too long then sometimes it take up to an hour for it to absorb water.
My circuit uses an AC signal because DC would cause unplating and corrosion of its probes.
http://www.electronics-lab.com/projects/science/018/index.html
Logged
MP
Electronics God
30+ Years Engineer
View Profile
« Reply #3 on: October 29, 2006, 11:01:45 AM »
Hi Alex,
Firstly, Welcome to the forum!
Do you have experience programming a micro? This would be the most interesting way to do it. Otherwise, you might want to use a timer. Either way, you really do not need a water monitor, per se. You just need a circuit that will activate a relay at a predetermined moisture level or predetermined time interval.
For either application, since the moisture in the soil changes the resistance of the soil, you can use a circuit which uses the resistance of the soil in a voltage divider to activate a comparator or transistor, then to a relay that activates the watering mechanism. For the timer idea, you would want to build a clock circuit and activate the relay at predetermined time periods.
Hopefully, this gives you some ideas. Good luck with the project!
MP
Logged
Pages: [1] Print
« previous next »
Jump to:
Advertisements
No New Posts
in
Advertisements
by google
Login with username, password and session length
Powered by MySQL Powered by PHP Powered by SMF 1.1.18 | SMF © 2013, Simple Machines Valid XHTML 1.0! Valid CSS!
Search Site | Advertising | Add your link here | Contact Us | Android TV Box
Elektrotekno.com | Free Schematics Search Engine | Electronic Kits | Electronic Accessories
