Frequency Counter
787
This is the Frequency Counter for 100Hz-2.5GHz, using LCD 16 chara.x 2 lines ,TCXO 12.8MHz(1ppm ) and PIC16F84. The Voltage (0-510mV) of the input signal is also indicated on the LCD , therefore tuning of the coil can be conducted while checking the frequency. Furnished with IF offset-function, this can be applied for the frequncr display of the home brewed transeiver. Print circuit board size is very small of 100mm x 43mm. [via]
Frequency Counter – [Link]
RELATED POSTS
Leave a Reply
