Function Generator with IC 8038 and LF351
2716
3
Mr. chai is want circuit Function Generator with IC 8038 for see guideline repair circuit. I find in web http://www.mitedu.freeserve.co.uk/Circuits see to this circuit very work sure.
Read detail :
Built around a single 8038 waveform generator IC, this circuit produces sine, square or triangle waves from 20Hz to 200kHz in four switched ranges. There are both high and low level outputs which may be adjusted with the level control. This project makes a useful addition to any hobbyists workbench as well.
All of the waveform generation is produced by IC1. This versatile IC even has a sweep input, but is not used in this circuit. The IC contains an internal squarewave oscillator, the frequency of which is controlled by timing capacitors C1 – C4 and the 10k potentiometer. The tolerance of the capacitors should be 10% or better for stability. The squarewave is differentiated to produce a triangular wave, which in turn is shaped to produce a sine wave. All this is done internally, with a minimum of external components. The purity of the sine wave is adjusted by the two 100k preset resistors.
Function Generator with IC 8038 and LF351 – [Link]
[via]
3 Response on “Function Generator with IC 8038 and LF351
Leave a Reply
