HAMMOND 1553T enclosures – keyboard and display in your hand
328
obr1248_1
In the Hammond 1553 enclosures series now can be found also types with a sufficient space for a keyboard and display.
Series of ergonomic handheld enclosures – 1553 is familiar to many of you. All types from this series provide a reliable grip thanks to a pleasant side overmold, they feature the same shape and they´re available in various sizes. That´s why, it is possible to choose the type exactly bespoken to your requirements. However there was a limitation, if you wanted to use a relatively large keyboard and a spacious display.
This problem is solved by the novelty – 1553T series. It provides a sufficient space for a keyboard and display and at the same time, it is somewhat thicker than other types of 1553 series, what enables to use several PCBs stacked on each other. That´s why, the 1553T series is ideal for various hand-held instrumentation, controllers, data capture and similar applications. The display and keyboard areas are recessed, what provides an additional protection (suitable also for membrane keyboards). 1553T enclosures are available in a black and a light-grey version and also with the battery compartment (battery contacts are included). Removable end panels (1 or 2 depending on version) enable easy modification and a trouble-free usage of connectors, IR components and other.
From a hand-held device, we naturally expect a higher dust and water resistance, what 1553T series with IP54 protection meets sufficiently. Last but not least – a relatively robust construction from a flame retardant ABS plastic and brass bushings give an assumption of a long lifetime and durability.
All 4 versions became our stable stock items, detailed drawings including 3D viewings can be found in datasheets at particular types. On the Hammond website, you can also find CAD files and 3D models. In case of interest in any HAMMOND products please contact us at info@soselectronic.com.
HAMMOND 1553T enclosures – keyboard and display in your hand – [Link]
Leave a Reply
