LED Desktop Clock
438
This project uses RGB LEDs to create a clock face. Each hand is assigned a colour and as the hands overlap on the face of the clock it mixes the colours.
The clock uses a single AA battery to power the display which is boosted to 5 volts with a switching mode power supply. The power supply should be able to use any AA battery that is at 0.7 volts or higher, which means that it should still work fine with AA batteries that may be “dead
RELATED POSTS
Leave a Reply
