LED Wizard calculates resistors and draws schematic
1434
The LED series/parallel array wizard is a calculator that will help you design large arrays of LEDs. You specify the source voltage, the led forward voltage, the led current and the number of LED and the calculator computes the schematic and resistor values. Check it out!
LED Wizard calculates resistors and draws schematic – [Link]
RELATED POSTS
Leave a Reply
