LM5117 / LM25117 – Powerwise Wide Input Range Synchronous Buck Controller with Analog Current Monitor
348
The LM25117 is a synchronous buck controller intended for step-down regulator applications from a high voltage or widely varying input supply. The control method is based upon current mode control utilizing an emulated current ramp. Current mode control provides inherent line feed-forward, cycle-by-cycle current limiting and ease of loop compensation. The use of an emulated control ramp reduces noise sensitivity of the pulse-width modulation circuit, allowing reliable control of very small duty cycles necessary in high input voltage applications.
LM5117 / LM25117 — Powerwise Wide Input Range Synchronous Buck Controller with Analog Current Monitor – [Link]
Leave a Reply
