Low-Voltage Cutoff Switch
1708
A microcontroller-based voltage cutoff circuit, currently in use on several motorcycles. It is designed to monitor the voltage level for the battery, and activate an accessory circuit when the level is sufficiently high. If the level drops below a calibrated level, the accessories are cut off.
Low-Voltage Cutoff Switch – [Link]
Leave a Reply
