LT3651-8.2 and 8.4 – Monolithic 4A High Voltage 2-Cell Li-Ion Battery Charger
911
4673_app_1
The LT®3651-8.2/LT3651-8.4 are 2-cell, 4A Li-Ion/Polymer battery chargers that operate over a 9V to 32V input voltage range. An efficient monolithic average current mode synchronous switching regulator provides constant current, constant voltage charging with programmable maximum charge current. A charging cycle starts with battery insertion or when the battery voltage drops 2.5% below the float voltage. Charger termination is selectable as either charge current or internal safety timer timeout. Charge current termination occurs when the charge current falls to one-tenth the programmed maximum current (C/10). Timer based termination is typically set to three hours and is user programmable (charging continues below C/10 until timeout).
LT3651-8.2 and 8.4 – Monolithic 4A High Voltage 2-Cell Li-Ion Battery Charger – [Link]
Leave a Reply
