Measure even a direct current with the clamp multimeter MS2102
245
With the MS2102 clamp multimeter you can comfortably measure not only alternate but also a direct current and voltage and all this at an outstanding price.
If you´re considering a purchase of a clamp multimeter, or if you already have a common multimeter and want a clamp version, then we have the device with an outstanding ratio of price to performance for you.
Sometimes it isn´t a problem to disconnect a measured circuit and to measure current by a common multimeter connected in series. However you may have already experienced a situation when it wasn´t possible to disconnect the measured circuit, from mechanical or electrical reasons. For these situations a clamp multimeter is an ideal choice. As it is well known, the biggest advantage of clamp multimeters is that they are able to measure a current flowing by a wire lead on the base of an induced magnetic field – without direct connection to a measured circuit. Thanks to the fact that a current is measured indirectly – the multimeter is at measuring galvanically isolated from a measured circuit, what provides a significantly higher safety to the user. From the principle of construction is the clamp multimeter suitable for measuring of mid to higher currents (above approx. 10 mA)
A big advantage of MS2102 is that it enables to measure also a direct current (DC). So for example to measure a current flowing to or from a car battery is with this device a breeze. Concurrently with measuring AC and DC current offers MS2102 also a possibility to measure also an AC and DC voltage, resistance to 400 Ohm and a continuity test. It contains an analogue bargraph and a maximal display value is 3999.
Measure even a direct current with the clamp multimeter MS2102 – [Link]
Leave a Reply
