Measure SMT components by only one hand
357
With multimeters VA 503 and VA 505B you don´t have to catch the SMT components on the table anymore! Speed and comfort of measurment with these multimeters will probably amaze you.
Measuring of resistance, capacity, diode and conductivity test – those are the tasks, which SMT tweezers handle with easiness. Naturally, all this can be measured also with a usual multimeter, but with one condition – usually you´ll need both hands for it and even so small SMT components have a tendency to jump out of measuring tips. At this process there is also an increased risk of damage to their sensitive soldering pads.
VA 503 and VA 505B SMT measuring tweezers eliminate all these nuisances. You only need one hand for measuring and measuring tips are fixed against side shift, thus a measured component practically cannot slip out of tweezers. From the principle of tweezers also one pleasant feature results – you can use the measuring tweezers also like a “usual tweezers
Leave a Reply
