MIT researchers print solar cell on paper
467
news.cnet.com writes:
CAMBRIDGE, Mass.–Scientists at the Massachusetts Institute of Technology have successfully coated paper with a solar cell, part of a suite of research projects aimed at energy breakthroughs.
Susan Hockfield, MIT’s president, and Paolo Scaroni, CEO of Italian oil company Eni, on Tuesday officially dedicated the Eni-MIT Solar Frontiers Research Center. Eni invested $5 million into the center, which is also receiving a $2 million National Science Foundation grant, said Vladimir Bulovic, the center’s director.
The printed solar cells, which Bulovic showed at a press conference Tuesday, are still in the research phase and are years from being commercialized.
However, the technique, in which paper is coated with organic semiconductor material using a process similar to an inkjet printer, is a promising way to lower the weight of solar panels. “If you could use a staple gun to install a solar panel, there could be a lot of value,” Bulovic said.
MIT researchers print solar cell on paper – [Link]
Leave a Reply
