Open source temperature controller
304
1
Michael writes:
My name is Karel and I’m creating an open source temperature controller. Please see the FAQ for open source licenses. I initially started this project because I make my own prototype PCBs at home, using the toner transfer method, and found out the laminator I use, a Scotch TL-901, doesn’t run hot enough and it took several passes to get the board hot enough. Instead of taking the time to reverse engineer the control board that was in the laminator, I decided to make my own.
After I finished the first prototype, I quickly realized there could be a lot of uses other than controlling a laminator. Some that came to my mind included using the board to modify a window A/C to be used in a walk in cooler, measuring inside and outside temp to control a green house, using it to control an aquarium heater, or even controlling egg hatching. I’m sure there are lots of other uses that the open source community will find.
Open source temperature controller – [Link]
RELATED POSTS
One Response on “Open source temperature controller
Leave a Reply
