Parallel Push-Pull 300B Tube Amplifiers
757
Rudolf Moers from the Netherlands has kindly sent us details of his parallel push-pull 300B monoblock tube amplifiers to share with the DIY Audio community. It should be quite obvious from the photographs that the design and construction of a pair of amplifiers this size is by no means a small undertaking. Rudolf tells us that he spent about 14 months designing and constructing the pair of monoblock amplifiers. The total cost of each amplifiers was about 1300 Euro, or about $1760US as of 29 September 2010. Each monoblock weighs 25 kg (55 pounds) and the overall dimensions are 530 mm deep, 390 mm high, 400 mm wide.
Parallel Push-Pull 300B Tube Amplifiers – [Link]
Leave a Reply
