Plants watering watcher
728
2
This project is a plant watering watcher that is able to flash a LED at a low rate when the soil in the pot plant becomes too dry. The circuit uses a CMOS quad Schmitt and is powered from two AA batteries. Check schematic and PCB boards on the link below.
Plants watering watcher – [Link]
2 Response on “Plants watering watcher
  1. This project was stolen from http://www.redcircuits.com where it replaces an earlier version that did not work.
    The IC is an ordinary CD4093 that has a minimum supply of 3.0V when the battery is new. But when the battery runs down a little then this IC will not work.
    The project should use the 74HC132 IC instead (it has different pins) because its minimum supply is 2.0V.
    I used the 74HC132 IC in my Plants Watering Watcher-2 project that is here.
Leave a Reply
