Real 3.3V Displays
361
DOG series will start with 3 types: 1×8 character, 2×16 and 3×16 character. Outline dimensions are very compact with 55x27mm and especially designed for handheld applications and low power applications. Thanks to the most modern Chip-On-Glas technology (STN and FSTN) overall height is 2.0mm only. Even together with LED backlight thickness will increase to 5.8mm only. Operating temperature range of –20..+70°C (temperature compensated) is standard.
Standard character height of 5.57 mm for the 2×16 makes „DOG modules“ easy readable. User can decide for 3 different interface 4-Bit, 8-Bit and SPI. No need to say that character set with full 248 ASCII characters is installed. Because of direct placement onto pcb production and mounting cost are unequaled low. No special mounting is required.
Combining various display technologies (positive/negative, blue/green/black) with different backlights (white, blue, amber, yellow/green, red) gives the advantage of many different design looks.
Real 3.3V Displays – [Link]
Leave a Reply
