Secret Arduino Voltmeter – Measure Battery Voltage
989
A little known feature of Arduinos and many other AVR chips is the ability to measure the internal 1.1 volt reference. This feature can be exploited to improve the accuracy of the Arduino function – analogRead() when using the default analog reference. It can also be used to measure the Vcc supplied to the AVR chip, which provides a means of monitoring battery voltage without using a precious analog pin to do so.
Secret Arduino Voltmeter – Measure Battery Voltage – [Link]
Leave a Reply
