Semiconductor analyser determines part type and value
674
1
Here is an interesting electronics gadget. It’s a semiconductor component tester that displays the type, pinout, and some relevant specifications of the device connected to its probes. [via]
It doesn’t matter how you connect the test clips to the component, the Atlas DCA can analyse a vast number of different component types including bipolar transistors, enhancement mode MOSFETs, depletion mode MOSFETs, Junction FETs (only gate pin identified), low power thyristors and triacs (less than 5mA trigger and hold), diodes, multiple diode networks, LEDs, bi-colour and tri-colour LEDs. It will even identify special component features such as diode protection and shunt resistors in transistors.
Semiconductor analyser determines part type and value – [Link]
One Response on “Semiconductor analyser determines part type and value
Leave a Reply
