Simple negative power supply (-5V / -12V / -15V)
408
Simple negative power supply (-5V / -12V / -15V) Sometimes you need a simple negative power supply. The best example is the contrast PSU for common small LCD device. Building -5V from a battery or a wallmart supply isn’t really easy.Here is a simple design small device that is able to provide -5V, -12V, -15V. He used the MAX 764/765/766 series. [via]
Simple negative power supply (-5V / -12V / -15V) – [Link]
Leave a Reply
