Simple Nokia LCD breakout board
252
Arup wrote a guest post about his Nokia LCD breakout board:
I designed a simple Nokia LCD Breakout board which allows you to interface any Nokia 6100 compatible display to microcontroller like PIC and AVR. The board itself provides 6.8volts for the backlight by a simple boost converter built up using a common 555 timer IC. There’s a switch to choose whether you want to work with 5V logic, or with 3.3V logic. [via]
Simple Nokia LCD breakout board – [Link]
RELATED POSTS
Leave a Reply
