Solar charger for lead-acid batteries
890
This project is used for charging sealed lead-acid batteries with a solar panel in small and portable applications. The charger will stop charging once a pre-set voltage (temperature compensated) has been reached, and resume charging when the voltage has dropped off. The load is disconnected when the battery voltage drops below 11V and reconnected when it gets back to 12.5V.
Solar charger for lead-acid batteries – [Link]
RELATED POSTS
Leave a Reply
